Old 10-24-2018, 05:00 PM   #12
RichardJ
Re: 230 head has crack, can I use a 250 or 292 head?
You should get a copy of Leo Santucci's 6 Cyl Chevy book
The 194 head is a good idea, only with the extra work aerotruk63 mentioned.
If the bell is damaged only in the starter bolt area, you may want to consider using a bolt-up starter motor. Some blocks are already drilled for a conventional bolt-up starter.
Santucci's book includes a template you can use to drill your block. Scan the page or trace the template.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
