Old 10-21-2018, 08:13 PM   #1
wick22
small back window glass
can anyone tell me the original rear glass thickness on a small back window 2nd series
I need really close measurement please
thanks in advance
wick22 is offline   Reply With Quote
Old 10-23-2018, 01:48 PM   #2
PDW HOTRODS
PDW HOTRODS's Avatar
Re: small back window glass
It is not flat like older trucks, so if you were going to have one cut I don't think it would work.
PDW HOTRODS is offline   Reply With Quote
Old 10-23-2018, 04:27 PM   #3
bowt1ed
Mine is out and measures at exactly .25", however, as stated, the glass is not flat, but rather domed.
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 10-23-2018, 09:18 PM   #4
wick22
im aware of that I just wanted to buy the lexan before I removed my glass and have it ready
its a street/strip truck that is getting lexan so itll easily bend and flex if needed
Old 10-23-2018, 09:18 PM   #5
wick22
Cheers, Jim
thanks a lot that helps
Old 10-23-2018, 09:33 PM   #6
MARTINSR
MARTINSR's Avatar
But laminated glass does flex some. I know I have put flat glass in a 56 I chopped years ago, not a problem.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 10-25-2018, 11:27 AM   #7
57tailgater
I think the key word here is "domed". It is curved in both directions which would be hard to achieve with a flat piece of plexiglass.
57tailgater is offline   Reply With Quote
Old 10-25-2018, 10:41 PM   #8
MARTINSR
MARTINSR's Avatar
But it's not, the original had a slight curve, I put flat glass there, done deal. It curved a bit flexing and it was done.
Brian
1948 Chevy pickup
Old 10-26-2018, 11:21 AM   #9
57tailgater
Brian
Yeah the curve is only slight so I could see where a flat piece could probably work. I didn't realize they are curved until I pulled an original one from a parts truck I had.
Old 10-26-2018, 06:27 PM   #10
PDW HOTRODS
The rubber gasket will flex some, and glass can flex some, but when the glass is flexed it has stress and will brake easy.
Old 10-26-2018, 06:50 PM   #11
MARTINSR
MARTINSR's Avatar
It never broke on the truck I did.
Brian
1948 Chevy pickup
