landarts
![]() Join Date: May 2005
Turn signal gunk ?
I am in the middle of wrapping up a build here on my 3/4 ton GMC 4x4. The steering wheel seem to have some slop in it so I pulled it off to find the upper bearing being completely worn out and one of the turn signal springs was snapped in half. So I ordered a new upper bearing and spring. Before I install them what is the best way to clean all the gunk out of the turn signal assembly as seen in the photo? I thought maybe Brake-Kleen or some degreaser and a rag.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
![]() Join Date: Mar 2015
Re: Turn signal gunk ?
I just finished a similar project. Cleaned with a small brush (tooth brush?) and rag with denatured alcohol. Seemed to clean it well, then finished by lubricating with white lithium grease.
landarts
Hey thanks I will give that a shot, I have some denatured alcohol and a few acid brushes.
Brakleen, Lectra Motive, Denatured, it's all alcohol and works well, leaves no residue. The cans make it easy to blast crud away.
