Old 10-28-2018, 07:35 PM   #26
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: What did you do to your truck today.The 3rd chapter
Got the 67 running and moving! Ran it up and down the driveway a few times and it should make the 10 mile trip to the new house this week.
Slid the rear axle under the 06 to move onto the trailer
Oil change and tire rotation for the Tahoe
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 10-28-2018, 08:02 PM   #27
Steeveedee
Who Changed This?
Steeveedee's Avatar
Pulled the alternator because the front bearing is noisy. It's been on there for a donkey's years. I couldn't get the rotor out of the front bearing. I'll just get a rebuilt one tomorrow. Turns out that it isn't the original, anyway. I wanted to rebuild it, they're easy (if you can get them apart).
~Steven
Simi Valley, CA
Old 10-28-2018, 08:03 PM   #28
jocko
jocko's Avatar
Originally Posted by RodnRudy View Post
I "winterized" Old Red today. Replaced the "mags" with the ralleys and while I had the rear wheels off I replaced the brake shoes and painted the new drums I bought at Auto Zone. I've never liked the drums I got at NAPA, they were not concentric, and causing a pesky vibration. I'll finish buttoning her up tomorrow after the paint on the drums is dry and take her for a test drive.
Phil, what did you paint your drums with? When I looked at the inside of the drums, I thought the blue tape was a reflection off of "highly polished" braking surfaces... Ha. Truck looks sharp!
Old 10-29-2018, 06:57 PM   #29
66clow
66clow's Avatar
Close to having it in one color. And plan to do it in red and white like this one. But my color choices changes day to day.
66clow is offline   Reply With Quote
Old 11-01-2018, 02:53 PM   #30
elorenzof
This past weekend I took of the Engine Crossmember and Installed a new freshly coated Crossmember, Upper and Lower Control Arms, New Steering Stuff ie: tie rods, pitman arm, etc... New Drop Spindles with Disc Brake Conversion kit.
elorenzof is offline   Reply With Quote
Old 11-01-2018, 03:44 PM   #31
OregonNed
OregonNed's Avatar
One of my side terminal bolts stripped the battery threads, so I moved wiring up to the top posts with new clamps. In the end, I moved the main cables over to the next smallest set screw opening for a better fit.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 11-01-2018, 04:42 PM   #32
FRCvette
Just finished changing oil on my 70. I am ready to drive again as soon as rain stops.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 11-01-2018, 05:06 PM   #33
morepwr
You guys are making me look bad! All I did was drive it to work today!
morepwr is offline   Reply With Quote
Old 11-01-2018, 05:14 PM   #34
samkost
samkost's Avatar
OregonNed,
Those are sharp.
I know they aren't OE but I really might have to get a pair of those top post Battery Terminals.
Thanks,
Sam
samkost is offline   Reply With Quote
Old 11-01-2018, 06:13 PM   #35
elorenzof
Originally Posted by Indychus View Post
I rolled it outside for the first time in 8 years and then test fit my headers!
WOW. Just. WOW.
Old 11-03-2018, 04:00 AM   #36
dflarsen77
Active Member
Slowly blasting and epoxy on the body pieces! Hoping to get it in paint by the end of the month!
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 11-03-2018, 04:02 PM   #37
70STOVEBOLT
70STOVEBOLT's Avatar
Removed the right side spindle and drum assembly to make way for the disc brake swap.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-03-2018, 07:34 PM   #38
elorenzof
I just did that job it went pretty well. What product did you choose to go with?
Old 11-03-2018, 09:33 PM   #39
kcmarkd
kcmarkd's Avatar
Today I replaced points, condenser, rotor, and cap. Set dwell angle and timing, then minor carb adjustments. And, even cooler, took it out on a short shake down cruise to the store to verify tuning and recent brake work. Didn't blow up, didn't crash, didn't die on the side of the road, and made it back home!
Oh, and drank a beer or several.
1970 C10 CST, PS, PB, AC, patina, original, work in progress
kcmarkd is offline   Reply With Quote
Old 11-03-2018, 11:54 PM   #40
tdangle
tdangle's Avatar
Replaced the passenger side vent rubber. Went way faster than the drivers side last week. I guess practice makes perfect
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-04-2018, 01:40 AM   #41
70STOVEBOLT
I mixed and matched components that were within my budget. I have around $400 in new stock height spindles, 12” drilled and slotted rotors, bearings and seals, master cylinder, brake hoses, calipers, pads, and prop valve.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 11-04-2018, 07:10 PM   #42
kcmarkd
kcmarkd's Avatar
Today I got my temp sensor tested, rewired, heat shrinked, and validated that it works!
Old 11-04-2018, 09:16 PM   #43
rpmerf
rpmerf's Avatar
Weekend recap:
Friday:
mounted new tires. Sumitomo Encounter HT 235/85R16 on freshly painted rims.
Saturday:
Had the running board offs for body mounts. Sand blasted and painted rockers and the bottom part of the doors. Drilled holes in running board brackets I welded together. Installed running boards. Set dwell, played with timing. Installed starter heat wrap. Not sure if it was the timing or the heat wrap, but it made an incredible difference.
Sunday:
Installed a new heater core.
A/F gauge seems to be reading leaner than usual. Not sure if I got an exhaust leak, or if it is just because of the fluctuating temperatures.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 11-04-2018, 09:41 PM   #44
Bomp
Bomp's Avatar
Decided to go a different route. Cut the front off.Name:  cutframe.jpg
Bomp is offline   Reply With Quote
Old 11-04-2018, 11:30 PM   #45
rjs53
Got the bed sides and hood painted, then started to so the patina work. I went with original color white, and black epoxy primer under it. I might add a little rust primer but kinda like the black and white look. Haven't decided weather ill put a satin or gloss clear coat.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 11-04-2018, 11:31 PM   #46
weq92f
weq92f's Avatar
Repaired broken negative battery terminal.
After finding all local parts stores had only 4ga replacement cables and most were too short... I needed 32" 2ga, I found a suitable replacement terminal
at the Orielleys parts house along with a 2ga brass lug and a 2ga solder pellet.
Cut the broken terminal off the end of my 2ga cable, used vicegrip plires to hold the lug while the pellet boiled and put my existing 2ga ground wire in. With continued heat, some of the solder wicked into the strands. Covered it all up with a piece of heat shrink wrap and done...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-05-2018, 06:39 AM   #47
72freak
Rottenwood Garage Member
72freak's Avatar
Drove it!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 11-05-2018, 07:09 AM   #48
snj8198
snj8198's Avatar
Latched onto my trailer and drug stuff around.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 11-05-2018, 11:50 AM   #49
beaterku
beaterku's Avatar
Finally have the engine assembled. It's been a long time coming. I've had this motor for 4 years now. Don't want to rush in to these things.
SBE LQ4 re-ringed and new bearings and a fresh hone
TSP 224r cam
LS7 lifters
LS2 timing chain
317 heads milled .030 & CNC'd with stock valves, PAC dual springs, trunion upgrade and hardened pushrods
beaterku is offline   Reply With Quote
Old 11-05-2018, 03:22 PM   #50
RodnRudy
RodnRudy's Avatar
Jocko, sorry for the slow reply, I don't look around here too regularly. The paint I used is Eastwood Extreme Chassis Black in Satin, also used their Chassis Black Primer. It's a pretty durable epoxy. I had it left over from when I painted my frame. Thanks for the kudos on my truck.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
