I need some help adding Power Steering to a 327
Looking for brackets, pics and/or part numbers to add a power steering pump to my 68 c10. 327 w short water pump.
I don't really want to switch it to the long water pump setup. I have a steering box. I think I know where to find a good, used pump. Anybody got a source for brackets? looks like I might need a different crank pulley? Thanks, Russ |
Re: I need some help adding Power Steering to a 327
Try here.
http://www.alangrovecomponents.com/ |
I think a donor with all the brackets, pulleys, pump etc off any short water pump V8 would be best. Aligniment, getting pulleys to line up is tough...mounting holes already in the 327?
This is a stock set up. You can buy the double crank pulley that nestles in the single. Belt for PS pump goes to outside.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#5 | ||
I would prefer original brackets, but might consider Geezers suggestion for an after market setup. |
I got some brackets and pulleys ,my 327 has the ps belt on the inside pulley cant remember if its original setup or not .
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
I bought a whole truck to do this to my '67. Drivetrain was long gone, but a got it cheap, kept a pile of parts, and sold it to a salvage man for almost as much as I paid for it. I highly recommend the process.
BTW--and this part will make some guys on here scream--the truck was a '68 model with a small rear window.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
I got a pump, mounts and crank pulley of ebay cheap cheap, all bolts straight up. All original and fits well. Just keep. An eye out on ebay.
#9 | |
It looks like that's the way I'm gonna go. I found the bracket and pulley for $95 I already have a pump, lines and steering box. The entire upgrade should cost about $150 including fluid. I've been meaning to do this for 4 or 5 years. My wife always tells me, she'd like to drive the truck, if it wasn't so hard to steer. ..I hope she still lets me drive it on occasion. ![]() |
Got my Alan Grove PS pump bracket and 3rd groove pulley today.
Nice unit, heavy duty, fits great. Painted it black and installed it. easy peasy. Pulleys line up perfectly, It's pretty slick. I can't wait to have power steering! |
![]() Join Date: Sep 2015
I did mine last year, well worth doing. Your going to need also a new pitman arm, a new rag joint. I found my pulleys on ebay for a gmc pickup. the pump and bracket i found at a you pull it junkyard, the steering box was in a box when i bought the truck. hardest part of the conversion was getting the bolt started at the motor mount.
