Old 10-30-2018, 04:07 PM   #1
gigamanx
Beginner Build with Ambition gets some air ride suspension.
Hey all! On my previous thread I mentioned phase 2 of the build would include suspension and possibly moving the gas tank.
So here we are! About an hour into the job and bed is already apart. I engineered it to come apart with a few bolts. Good job past-me.
First question for the forum, before I blow into the 3-link rear setup from RideTech, is.... do I need to weld a support to the axle and frame to keep the axle in the same position, or can I simply take the current suspension all apart and start installing the 3 link? I don't want to have to modify the driveshaft now that I have it dialed in. I'm guessing since the RideTech 3 link is a bolt-in, the spacing geometry for the rear axle is probably pretty much set anyway.
The goal for this winter is getting the whole truck on an accuair e-level bag kit along with the ridetech 3 link rear and 2" front drop spindles. The build may mean I have to move my gas tank and do an underbed install. That is yet to be determined.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
