Old 10-31-2018, 09:57 AM   #18
hatzie
Moderator
hatzie's Avatar
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
The hardened and ground bearing surface finish on a new or serviceable used countershaft should be absolutely smooth. Just like a freshly ground crankshaft journal... maybe smoother.
How rough is yours where the needle bearings ride?
The reason I ask is... It looks like you have at least four well defined wear rings from the needle bearings. The two on the slotted end look rough enough that I would consider a new countershaft... or spray welding and re-grinding back to spec.
How does the countershaft needle bearing bore opposite those wear rings look and feel?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
