Old 03-10-2018, 03:23 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
front crossmember-pre runner bumber Build
Hay everyone id like to share my most recent update to my truck
this idea started out of the blue and a piece of 12in x 3/8in flat plate.
it may not be what you like or built the way you woud do it but its 100% my truck and my idea and i think it turned out ok.
whole thing is bolt on using factory frame holes (+ some holes) with 1/2in and 5/8ths grade 8 bolts and the bumber can be removed from crossmember.
tubing is 1 1/2in .120 DOM
only tools used were a welder and and angle grider.
hope you enjoy.
SO IT STARTS- FRAME WIDTH X12in FLAT PLATE SCORDED AND HAND BENT, SEEMS WELDED UP GROUND DOWN AND SMOOTHED.
(MY IDEA WAS A CROSSMEMBER THAT WOULD WRAP AROUND FRONT OF TRUCK FRAME.
CROSSMEMBER ALL DONE
STARING TUBE BUMBER DESIGN-ANGLE OF 1970 GMC GRILL
MATCHING TUBE ANGLE WITH GRILL ANGLE
THE 2 (OUTER ANGLES) LINE UP WITH INSIDE OF HEADLIGHT BUCKETS
1/4in PLATE USED FOR FRAME TIE INS
HUGS THE FRAME
NOT ME :-)
DESIGNED IT TO LINE UP WITH BOTTOM OF GRILL
ALL DONE
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 03-28-2018, 12:06 AM   #2
nrb's70gmc
nrb's70gmc's Avatar
Re: front crossmember-pre runner bumber Build
Current project. Tubular upper control arms. Built not baught
Old 10-26-2018, 03:12 PM   #3
68 P.O.S.
Looks great!
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-26-2018, 03:29 PM   #4
Mike C
Mike C's Avatar
Nice fab. I will be watching for updates.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-26-2018, 07:09 PM   #5
nrb's70gmc
nrb's70gmc's Avatar
Update. I fabbbed some rectangular tubing upper arms. To be used with uniballs instead of ball joints.
Going to modify lower stock arms and will run a uniball set up there to.
Current project. Fabbing lifted spindles. Then front/rear disc brakes -hydroboost setup.
Already baught - 40x13.50x17 toyo mt. / real beadlocks - Atx slabs
Old 10-30-2018, 10:32 AM   #6
68 P.O.S.
Are you going to run the truck in the desert or is this more for looks?
Old 10-31-2018, 07:50 AM   #7
Nice work. I'm liking your plan. You'll be having a true custom concept/build. Nice!
Old 10-31-2018, 08:43 AM   #8
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks nice, I'm in to see more
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 10-31-2018, 03:15 PM   #9
nrb's70gmc
nrb's70gmc's Avatar
Thanks everyone for the positivity. Some think its impossible or I dont have enough resources to build my idea.
