10-28-2018, 07:35 PM | #26 |
Moderator
Re: What did you do to your truck today.The 3rd chapter
Got the 67 running and moving! Ran it up and down the driveway a few times and it should make the 10 mile trip to the new house this week.
Slid the rear axle under the 06 to move onto the trailer Oil change and tire rotation for the Tahoe
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
10-28-2018, 08:02 PM | #27 |
Who Changed This?
Pulled the alternator because the front bearing is noisy. It's been on there for a donkey's years. I couldn't get the rotor out of the front bearing. I'll just get a rebuilt one tomorrow. Turns out that it isn't the original, anyway. I wanted to rebuild it, they're easy (if you can get them apart).
10-28-2018, 08:03 PM | #28 | |
10-29-2018, 06:57 PM | #29 |
Close to having it in one color. And plan to do it in red and white like this one. But my color choices changes day to day.
11-01-2018, 02:53 PM | #30 |
This past weekend I took of the Engine Crossmember and Installed a new freshly coated Crossmember, Upper and Lower Control Arms, New Steering Stuff ie: tie rods, pitman arm, etc... New Drop Spindles with Disc Brake Conversion kit.
11-01-2018, 03:44 PM | #31 |
One of my side terminal bolts stripped the battery threads, so I moved wiring up to the top posts with new clamps. In the end, I moved the main cables over to the next smallest set screw opening for a better fit.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
11-01-2018, 04:42 PM | #32 |
Just finished changing oil on my 70. I am ready to drive again as soon as rain stops.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
11-01-2018, 05:06 PM | #33 |
You guys are making me look bad! All I did was drive it to work today!
11-01-2018, 05:14 PM | #34 | |
Those are sharp. I know they aren't OE but I really might have to get a pair of those top post Battery Terminals. Thanks, Sam Last edited by samkost; 11-01-2018 at 05:20 PM. Reason: post |
11-01-2018, 06:13 PM | #35 |
11-03-2018, 04:00 AM | #36 |
Active Member
Slowly blasting and epoxy on the body pieces! Hoping to get it in paint by the end of the month!
David Larsen 1970 Chevrolet C-10 |
11-03-2018, 04:02 PM | #37 |
Removed the right side spindle and drum assembly to make way for the disc brake swap.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-03-2018, 07:34 PM | #38 |
11-03-2018, 09:33 PM | #39 |
Today I replaced points, condenser, rotor, and cap. Set dwell angle and timing, then minor carb adjustments. And, even cooler, took it out on a short shake down cruise to the store to verify tuning and recent brake work. Didn't blow up, didn't crash, didn't die on the side of the road, and made it back home!
Oh, and drank a beer or several.
1970 C10 CST, PS, PB, AC, patina, original, work in progress |
11-03-2018, 11:54 PM | #40 |
Replaced the passenger side vent rubber. Went way faster than the drivers side last week. I guess practice makes perfect
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-04-2018, 01:40 AM | #41 |
I mixed and matched components that were within my budget. I have around $400 in new stock height spindles, 12” drilled and slotted rotors, bearings and seals, master cylinder, brake hoses, calipers, pads, and prop valve.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by 70STOVEBOLT; 11-05-2018 at 01:42 PM. |
11-04-2018, 07:10 PM | #42 |
Today I got my temp sensor tested, rewired, heat shrinked, and validated that it works!
11-04-2018, 09:16 PM | #43 |
Weekend recap:
Friday: mounted new tires. Sumitomo Encounter HT 235/85R16 on freshly painted rims. Saturday: Had the running board offs for body mounts. Sand blasted and painted rockers and the bottom part of the doors. Drilled holes in running board brackets I welded together. Installed running boards. Set dwell, played with timing. Installed starter heat wrap. Not sure if it was the timing or the heat wrap, but it made an incredible difference. Sunday: Installed a new heater core. A/F gauge seems to be reading leaner than usual. Not sure if I got an exhaust leak, or if it is just because of the fluctuating temperatures.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
11-04-2018, 09:41 PM | #44 |
Decided to go a different route. Cut the front off.
11-04-2018, 11:30 PM | #45 |
Got the bed sides and hood painted, then started to so the patina work. I went with original color white, and black epoxy primer under it. I might add a little rust primer but kinda like the black and white look. Haven't decided weather ill put a satin or gloss clear coat.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
11-04-2018, 11:31 PM | #46 |
Repaired broken negative battery terminal. After finding all local parts stores had only 4ga replacement cables and most were too short... I needed 32" 2ga, I found a suitable replacement terminal at the Orielleys parts house along with a 2ga brass lug and a 2ga solder pellet. Cut the broken terminal off the end of my 2ga cable, used vicegrip plires to hold the lug while the pellet boiled and put my existing 2ga ground wire in. With continued heat, some of the solder wicked into the strands. Covered it all up with a piece of heat shrink wrap and done... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
11-05-2018, 06:39 AM | #47 |
Rottenwood Garage Member
Drove it!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
11-05-2018, 07:09 AM | #48 |
Latched onto my trailer and drug stuff around.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
11-05-2018, 11:50 AM | #49 |
Finally have the engine assembled. It's been a long time coming. I've had this motor for 4 years now. Don't want to rush in to these things.
SBE LQ4 re-ringed and new bearings and a fresh hone TSP 224r cam LS7 lifters LS2 timing chain 317 heads milled .030 & CNC'd with stock valves, PAC dual springs, trunion upgrade and hardened pushrods |
11-05-2018, 03:22 PM | #50 |
Jocko, sorry for the slow reply, I don't look around here too regularly. The paint I used is Eastwood Extreme Chassis Black in Satin, also used their Chassis Black Primer. It's a pretty durable epoxy. I had it left over from when I painted my frame. Thanks for the kudos on my truck.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
