#26 |
HOW long until spring??
![]() Join Date: Mar 2009
Re: Cheap cheap bed floors??
Grumpy-I Saw a 66 long bed with TREX decking (the plastic boards) and chrome strips that looked really nice. I am planning on using that for my 64 shortbox. Use your router just like on wood.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#27 |
But Found Her 25yrs Later!
So, an 8' sheet of plywood is long enough?
#28 |
That's what I did. 2 sheets exterior grade split in the middle. Longbed needs 9 foot sheets
#29 |
60-66 Nut
Are you asking about a shortbed or a longbed? IIRC the wood in a longbed fleetside measures 97.5"
#30 | |
I was asking for a longbed.
#31 |
Moderator
![]() Join Date: Dec 2012
Not long enough for a longbed. I used 10' lengths cut down.
#32 |
I used composite boards for mine. Changed them this past summer. You will actually use the Facia boards instead of the deck boards. I got mine at Lowes. It is the gray color. I painted my metal strips black. Looks like an old truck bed but it won't rot. The only thing I would do differently is to add a cross member at the back end just past the fender wells. It is sturdy and looks great. Adding a cross member would make it even sturdier. I'll post pics if you need them. Take care.
#33 |
![]() Join Date: Aug 2017
#34 |
Treated 3/4" plywood & stainless steel strips.
As Mr. Spock would say: "Crude but effective". |
#35 |
1962 C-10
My buddy hooked me up with some aluminum sheets...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#36 |
Treated, torched, finished plywood from Lowes with painted strips. I think the finished product looked a little better with the hardware installed. I snapped this pic during the process though.
#37 | |
Any more info you can provide? Are the Facia boards 3/4" thick or a different dimension?
#38 |
Yes. they are 1x8's. Same dimensions as traditional lumber. Looked up the groove pattern and cut everything like a traditional board from the factory. Some say that the boards aren't rigid. Well.. Besides the back of your truck where you don't have a cross member, everything else works great. I just used whatever was at the big box store. I haven't restored my truck yet. When I do I may order boards in a particular color that would look nicer. I'll try to get some pics tonight.
#39 | |
#40 |
Moderator
Google my TREX posts, you'll see exactly how I did it.
