Old 11-01-2018, 05:01 PM   #1
brutalblake
1952 Chevy Flatbed steering question
where I work they have a 52 flatbed that has been part of the department since day one. Recently someone had got the bright idea to rebuild it, and all original at that (or as close as possible). That being said...
A former employee started this project 2 years ago and its been sitting for the last year. I'm in charge of picking up where he left off. Unfortunately, it's a bit of a mess trying to find out what's been done.
At the moment I'm trying to track down a pitman arm for the steering box. The steering box was rebuilt and I'm not sure if they put a different splined gear, because it is too small for the opening in the current pitman arm. Every pitman arm I lookup is for power steering, which is what we are trying to avoid.
If anyone knows where I can find what the original specs were or knows a good place to start searching I would be beyond grateful.
brutalblake is offline   Reply With Quote
Old 11-01-2018, 05:48 PM   #2
whitedog76
Re: 1952 Chevy Flatbed steering question
Is it a 3100, 3600, 3800, etc... truck?
Also if you can take a measurement of the shaft with a caliper, that would be helpful.
There’s a lot of good guys on forums like this one and Stovebolt.com that rare willing to help too.
whitedog76 is offline   Reply With Quote
Old 11-01-2018, 05:49 PM   #3
mr48chev
mr48chev's Avatar
It sounds like they used the sector shaft out of a smaller truck during the rebuild.
I honestly don't know where the size break in steering box and pitman arms is on these trucks.
My ongoing truck projects:
Old 11-01-2018, 06:10 PM   #4
brutalblake
I believe its a 3800. the pitman arm is 9.5" center to center and has a female spline insert with 28 teeth and a diameter of 30mm. The steering box has a male spline shaft with 32 teeth and is 28mm in diameter.
I know the steering box was rebuilt. I just located a receipt from last November. So I'm assuming they put the wrong spline shaft (sector shaft) in.
Old 11-01-2018, 09:39 PM   #5
1project2many
https://www.ebay.com/itm/NOS-51-54-C...UAAOSwqu9U75EB
I think I counted 32 spline...
1project2many is offline   Reply With Quote
Old 11-05-2018, 05:24 PM   #6
brutalblake
So those four slightly wider grooves, I was not counting. If you are supposed to count those than I am four shy on both my previous counts.
pitman arm, steering box
