11-04-2018, 09:17 PM | #1 |
Bed cross sill BRACKETS and pads
these bracket and pads are not wide enough.
where can I get wider ones?, they need to be closer to 3" wide. |
11-04-2018, 10:49 PM | #2 |
Re: Bed cross sill BRACKETS and pads
Here's the link to the Mar-K set http://www.mar-k.com/Catalog/index.aspx?LID=2514
I thought the metal pieces came already welded to the cross braces.
11-04-2018, 11:02 PM | #3 |
...or fab the brackets with a vise and a hammer and make the pads out of any kind of rubber. The brackets are important because they keep the cross sills from spreading, and rubber or metal shim added to the pad here and there helps level the tops of the cross sills if necessary, so don't leave home without 'em!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) Last edited by DransportGarage; 11-04-2018 at 11:08 PM. |
11-05-2018, 08:42 AM | #4 | |
Yea I'v had to make a lot of things so I guess I will have to make them. I do have a cheep 3' brake. Those mar-K rubbers do look wider Thanks guy's |
11-05-2018, 05:15 PM | #5 |
i boxed the frame and welded angle iron brackets to the boxed sections, made 10 ga square washers and welded them on, inboard of the stock holes
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-05-2018, 06:16 PM | #6 |
Ogre
Really nice build |
11-05-2018, 07:55 PM | #7 |
Just to give you another idea. I boxed my frame too, but before I did I welded nuts under the original holes so I could screw bolts under them. I NEVER think ahead like this, but at least this time I did.
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
