11-08-2018, 03:14 AM | #1 |
1969 C20 Drive Shaft Center Support
I need to order a replacement drive shaft center support bearing for my 69 C20. All the ones I see pictures of look different than what is in my truck now. It appears to be 2 pieces bolted together and no visible rubber surrounding the bearing. Any ideas? Big block with leaf springs if that helps.
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green. |
11-08-2018, 07:18 PM | #2 |
Re: 1969 C20 Drive Shaft Center Support
That is the HD support bearing. Same one that's on my leaf spring shorty actually. And here is a link to what I found:
http://67-72chevytrucks.com/vboard/s...d.php?t=656307
11-08-2018, 11:35 PM | #3 |
What they said! Leaf spring trucks and 3/4 ton and up have different carrier bearings than most 1/2 ton coil spring trucks.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-09-2018, 12:58 AM | #4 |
Thank you, that is just the information I needed.
