#1 | |
Bloo
disc brake question
can i use 69 a-arms, and 71-87 spindles?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Check the FAQ section , there is a front end article in there that addresses this, I believe.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
![]() Join Date: Feb 2000
Blue 71,
Yes you can, but you need ball joints for the year of Spindles you use. You also need the Inner&Outter Tie Rods and the center link. |
Yes I have done it you will need ball joints for the spindle year. I have a 69 and put 72 disc on it. the problem was the tie rod ends neither year would work together. Let me know and I will see if I can find the part numbers for the tie rod ends.
