Old 11-11-2018, 11:32 AM   #1
the ideaman
the ideaman's Avatar
Help! Bolt in exhaust pass through?
I've seen these here on several member's trucks. They bolt into the crossmember and allow the exhaust to pass through. Can somebody tell me the company that make these? Thanks in advance.
the ideaman is offline   Reply With Quote
Old 11-11-2018, 11:36 AM   #2
Zeroman
Zeroman's Avatar
Re: Help! Bolt in exhaust pass through?
Dead End Garage
https://azproperformance.com/product...outs-63-72-c10
Zeroman is offline   Reply With Quote
Old 11-11-2018, 04:11 PM   #3
PepperTreeGarage
PepperTreeGarage's Avatar
Brothers also has them.
https://www.brotherstrucks.com/63-72...tinfo/ECOB072/
PepperTreeGarage is offline   Reply With Quote
Old 11-11-2018, 05:39 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
Unless you have 1000 HP you don’t need them
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-11-2018, 07:03 PM   #5
HO455
HO455's Avatar
I'm not sure of your logic here. Can you explain further?
RIP Bob Parks.
Old 11-11-2018, 07:09 PM   #6
Grumpy old man
Grumpy old man's Avatar
I'm pretty sure he's talking about frame twist without bolting or welding in tube support after cutting cross member . I just cut 4" holes and welded in tube support total cost was $20.00 for the tube . A lot of these old trucks have "chevy twist" in the frame with stock engines ,So throwing a 1000 at a stock frame holes or not will probably have the frame looking like a pretzel .
Old 11-11-2018, 07:39 PM   #7
70STOVEBOLT
There is a member here, can’t recall his handle, that cut holes in his crossmember and has been running it that way for several years without reinforcement and he has a healthy big block IIRC. I cut 3” holes in mine instead of 4” and don’t plan on reinforcing it.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 11-11-2018, 07:44 PM   #8
un4gvn!
un4gvn!'s Avatar
All I did was hole sawed two 3" holes in the cross member with out welding any thing. I use 3" exhaust which was a very tight fit and the holes act as the hangers. I'm throwing at least 600 hp through the pipes and my frame still looks good. The paint isn't even burning off.
un4gvn! is offline   Reply With Quote
Old 11-11-2018, 08:29 PM   #9
truckster
truckster's Avatar
I think that looks way more solid than a bolt-in piece. It looks like the crossmember was made that way.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
