Active Member
![]() Join Date: Mar 2018
Need some frame expert help
I think I posted a pic of the damage of the front frame cross member on a truck I purchased a while back. I have a friend who has an early 80's frame that the cross member is in excellent condition. He says the frames are the same from 67 to the early 80's as far as the front section is. Can anyone verify that this would work on my 72? Appreciate any help. Photo of my damaged one for reference. Thanks again
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
Re: Need some frame expert help
You may opt for swapping out the whole front cross member, axle hub to hub, cross members fit thru "87"...That's what's under my "72" works fine.
#3 | |
Active Member
I would imagine to swap the front cross member the engine will either need to come out or some way be supported? Thx again
At the body shop.
Be easier with the engine out.
Could also use the clamshell style motor mounts as well.
" That didnt make it any newer " " Dont antique the equipment " |
#5 | |
The Older Generation
LockDoc
Active Member
Thank you sir for the additional info. Appreciate it.
