Old 11-13-2018, 08:42 PM   #1
jlampka
Th400
I am buying a 1972 GMC with a TH400 tranny and limited slip differential. I was thinking of renting a tow dolly to drive up on with the front wheels and the rear wheels will be in contact with the road and pull it home with my Silverado. Will I damage the rear end?
jlampka is online now   Reply With Quote
Old 11-13-2018, 09:27 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Th400
Tow with the front wheels on the road and rear wheels on the dolly, or disconnect the drive shaft at the rear u-joint and tie the drive shaft up under the truck with a strap. Chock the wheels when you're up under there disconnecting the u-joint.
Old 11-13-2018, 09:52 PM   #3
jlampka
Re: Th400
Thank you!
Old 11-14-2018, 07:04 AM   #4
Re: Th400
Dollies are designed to haul with turning wheels on dolly/rear on the road. So pull the shaft loose at the rear and keep shaft in place. It's the transmission you are saving. None of this matters to the rear.
