Old 11-15-2018, 11:56 PM   #1
MARTINSR
MARTINSR's Avatar
Another stupid question, what is this?
This was bolted to the center crossmember, what is it?
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-16-2018, 12:03 AM   #2
MiraclePieCo
MiraclePieCo's Avatar
Re: Another stupid question, what is this?
I can definitely identify that as a rectangular piece of metal (probably steel, judging by the rust) with four holes and an odd bracket attached on one end.
Glad I could help.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 11-16-2018, 12:05 AM   #3
MARTINSR
MARTINSR's Avatar
Glad I could help.
Is it REAL rust or is it fake patina?
Brian
1948 Chevy pickup
Old 11-16-2018, 01:55 AM   #4
mick53
Brian
It's a dangleflapper. Only came on California trucks.
mick53 is offline   Reply With Quote
Old 11-16-2018, 02:18 AM   #5
mr48chev
mr48chev's Avatar
I've seen them but right now can't remember what they do. Exhaust support or center support for the driveshaft on long wheelbase trucks?
My ongoing truck projects:
Old 11-16-2018, 06:32 AM   #6
dsraven
the only thing I can think of is a muffler hanger that bolted directly to a round muffler body as seen on some large trucks. otherwise, possibly a muffler bearing retainer or a bracket for a hidden doo hickey .
oh, wait! now I remember. it's a retainer for the down grease tube for the feather valve on the gooseneck trailers used back in the day. I would put that thing on ebay and get a few bucks for it. you just don't see those things anymore. should be worth something to somebody......
hahaha, dunno. if the truck had a pto at some time it could possibly be a bracket for a driveshaft bearing to a hydraulic pump or something along that line?
Old 11-16-2018, 07:57 AM   #7
Killer Bee
Killer Bee's Avatar
can you put it back and post a picture so we can see it's proximity to the drivetrain?
model and year of truck?
any other stray brackets or out of place bolt holes in that area?
if it's not a typical part commonly found in your model, my swag would be a trans mount yoke for non-typical transmission or add-on brownie box of some kind, maybe even overdrive unit or pto support, something along those lines..
or driveshaft brake mounting bracket of some kind, also maybe aftermarket since it's kind of crude and simple in design..
if not any of those, I'm going with flux capacitor, used to be able to get them at O'Reilly's.. https://www.oreillyauto.com/flux-capacitor
good luck!
Old 11-16-2018, 09:06 AM   #8
MD2020
MD2020's Avatar
Looks like a lower shock mount, it would be bolted to the U bolts for the leaf springs
MD2020 is offline   Reply With Quote
Old 11-16-2018, 10:24 AM   #9
MARTINSR
MARTINSR's Avatar
good luck!
Luckily I took plenty of photos of the frame before I disassembled it. My truck is a mismosh of years, don't even know what year the frame is, 51-53?
Brian
1948 Chevy pickup
Old 11-16-2018, 10:26 AM   #10
nvrdone
if I remember correctly, that's a rear trans mount for a torque tube drive line. the 4 holes bolt to the crossmember & the u shaped part bolts to the end of the trans.
nvrdone is offline   Reply With Quote
Old 11-16-2018, 10:32 AM   #11
MARTINSR
MARTINSR's Avatar
Makes sense, thanks! Seems kinda flimsy for that but that is exactly where it is mounted, it has to be.
Brian
1948 Chevy pickup
Old 11-16-2018, 05:44 PM   #12
mick53
It was hard to tell from the first picture because of the missing bolt.
Old 11-16-2018, 10:59 PM   #13
cmayna
Are you guys serious? Yes it's a standard SM420 / Torque tube cross member support bracket.
Craig
My truck '50 Chevy 3100-5 window
If I'm not working on my truck, I'm fishing with the wife or smoking Salmon.
cmayna is offline   Reply With Quote
Old 11-16-2018, 11:31 PM   #14
mr48chev
mr48chev's Avatar
We aren't restorers, we remember we saw it and took it off but forget what it did.
Old 11-17-2018, 01:41 AM   #15
mick53
I took mine off in 1980
Old 11-17-2018, 01:47 AM   #16
MiraclePieCo
Let's see...we called it a flux capacitor, a dangleflapper, a muffler bearing retainer, and a rectangular piece of steel. And you think we might be serious?
Old 11-17-2018, 10:54 AM   #17
cmayna
LOL, I sure wasn't serious about being serious. But yes it's a SM420 to torque tube ball joint support bracket. MartinSR, if you don't plan to use it, I'd love to give it to a friend who needs one. Trade for some smoked salmon?
Craig
Old 11-17-2018, 11:20 AM   #18
MARTINSR
MARTINSR's Avatar
I will not be using it let me know where I can send it.
Brian
1948 Chevy pickup
Old 11-17-2018, 01:48 PM   #19
Killer Bee
Killer Bee's Avatar
I'll send you Brian's mailing address for the smoked salmon
Old 11-17-2018, 07:09 PM   #20
cmayna
MARTINSR,
Sent you a PM. No, seriously!!
Craig
Old 11-17-2018, 07:37 PM   #21
mr48chev
mr48chev's Avatar
I took mine off at midnight one night in 1973 after I drove the truck home with the Nova rear with spring pads welded on in the back, pulled it in the garage. jacked the back up, pulled the rear and swapped rears and then swapped transmissions and had it back together in time to go to work the next afternoon. That same process would probably take me a week now.
Old 11-17-2018, 07:45 PM   #22
cmayna
Add another week for me.
Craig
Old 11-17-2018, 08:47 PM   #23
greg_h
Bingo!
greg_h is offline   Reply With Quote
Old 11-18-2018, 08:48 PM   #24
slammed57
flux capacitor?
slammed57 is offline   Reply With Quote
Old 11-18-2018, 11:50 PM   #25
MiraclePieCo
If you have the same luck mailing Brian the smoked salmon that I had mailing him a Factory Assembly Manual, the Post Office crew will have fish breath for days.
