Leaky Glovebox
Got a problem folks, Replaced my windshield new gasket and put a new glove box in and rained one day and had a puddle in my glove box
looks like the leak is coming from the back right corner off the glove box looking in. Any idea of how to fix this anyone?
Re: Leaky Glovebox
Easy fix!
Put a drain hole in the glove box! JK! LOL!! Your new windshield gasket is no good. |
![]() Join Date: Nov 2012
Re: Leaky Glovebox
When I had my windshield replaced in my 81 C10 the glass installer advised me that it takes a few days up to a week for the gasket to properly seal and that leaks were a possibility.
If it is a week past that time I would recheck the gasket to see if it is bad or not properly sealed.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
Re: Leaky Glovebox
Is it your windshield gasket or the body seam? I don’t have any tips for you but mine leaks through a seam where the filler has come out ( i haven’t got to fixing it yet
). If water gets through the seam, it follows the post down to the dash, or wherever gravity takes it. Mine will leak more if I park slightly “ nose down”
The Older Generation
Re: Leaky Glovebox
Try using a little windshield sealer 6" in from the top corners and 3" down from the top corners of the windshield gasket. That may help the leak problem. Also check the inside of the drip rail and the seam below it and chalk as necessary. The glove box liners have a seam on both sides and the lap in the seam is open at the top, so any water that leaks on the top of the liner runs down into the glove box. You can see what I'm talking about in the picture below. I always use sealer to seal up the gap in the seams before installing the glove box liners. I use a product called DAP tub & tile chalk. You can get it at any hardware store. LockDoc
#6 | |
![]() Join Date: Mar 2000
Re: Leaky Glovebox
Paul Sr @ GMCPauls |
Re: Leaky Glovebox
Yup, windshield is supposed to be cemented into place in order to be weathertight.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Re: Leaky Glovebox
Thanks everyone its been a few weeks was replaced but im going to take a bucket of water with me and see if I can pin point the leak and patch with sealer.
Re: Leaky Glovebox
Sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
Re: Leaky Glovebox
Well think Ive fixed the problem? months ago I removed the antenna wire and the whole left was causing water to leak in.
Re: Leaky Glovebox
Also, the upper corners can leak. Its common to fold back and put windshield silicone in there.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#12 | |
Re: Leaky Glovebox
Re: Leaky Glovebox
Yes I did they do work at my fathers work and was able to get a deal and they didnt have any problem getting the seal they had it in stock. When it was installed he used some sealer too under the gasket along a spot or two on the top so im sure the hole I patched with the quarter was the problem.
#14 | |
All about them K’s
![]() Join Date: Jun 2014
Re: Leaky Glovebox
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
| Bookmarks |
