Old 11-10-2018, 09:20 PM   #26
AussieinNC
Moderator
AussieinNC's Avatar
Re: Move dash wires = no start
Post a pic when you can....but as an interim....
Place a small gauge jumper wire with an inline fuse built in, between the Positive battery post and the junction block, and try the headlights....if the fuse blows, the headlight circuit has a short somewhere...
Remove one end of the fusible link and using an multi meter set to Ohms, measure the resistance of the fusible link....If it is open circuit, it has burned up due to a short somewhere...
To me it sounds like the fusible link melted causing a loss of supply voltage to not only the headlights but also the Ignition switch circuits....
These old trucks are a basic system that has several fail points,,,,bad grounds, corroded connections at connection plugs, especially firewall to cab connectors and failed fusible links...plus the occasional bad component like an Ignition switch or solenoid...
I would concentrate on one item at a time...with first item to test being the fusible link...
If it fails you will have a truck with nothing that works...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 11-16-2018, 04:42 PM   #27
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
***update***
Ok, half of the problem has been solved. The electrical loss is fixed. And it was almost impossible to find because it was completely invisible. I had visually checked the junction block several times, and it always seemed fine. But this time as I was using a jumper wire on it to attempt to trace this issue I noticed something. There are four wires attached to the junction block, and they were all loose. The bottom one had a round wire connector that had once been turned sideways/diagnally when the junction block nut was tightened on top of all of them. It apparently stayed sideways which gave the truck power, but then the vibration loosened it, and it no longer acted as a connector since it created space between the other connectors. I know this is what happened, because I know that I did not leave that nut so loose. The junction block completely obscured this wire issue.
So it still turns over, but does not fire.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 11-16-2018, 05:47 PM   #28
Stocker
20' Daredevil (Ret)
Stocker's Avatar
One problem solved.... on to the next!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-16-2018, 06:43 PM   #29
68Gold/white
Yes...power to coil with key on???
68Gold/white is offline   Reply With Quote
Old 11-16-2018, 07:05 PM   #30
HIGHWAY BY THE SEA
Ok...the joke's over...
The truck is running again!!!!!!!!!! Now I am MAD!!!!
It has taken me until today to be able to work on the truck due to work and inclement weather.
After I found this joke of an electrical problem and fixed it, I began to look for the next problem. And to accomplish this I simply looked to the one place where I had not looked yet that I was so sure could not possibly be the issue...
THE GAS TANK!!!!!!
Yes!!! And there I found an even bigger joke!!! EMPTY!!!!!!!
This perfect storm was all a big celestial joke on me!!!!
The junction block wire started popping loose coincidentally at the same time that unbeknownst to me the gas tank was running low, AND when I was moving dash wires out of my way to work on the interior!!!!
GRRRRRRRRRRR!!!!!!!!!!!!!!!!!
This all created the illusion that I had somehow disabled the entire electrical system by moving those damn wires!!!!!
Two gallons of gas sure did not go far in this truck that I have,so far, only driven in my driveway!!!!
This goes to show how truck mechanical/electrical symptoms can be coincidental and very misleadling!!!!
Thanks millions to all of the great people who tried to assist
Old 11-16-2018, 08:42 PM   #31
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Sorry, didn't mean to laugh at your expense... Gotta wonder how many of us have had similar 'coincidental' truck problems?
Glad it's running, btw!
- Mike -
RIP El Jay
Old 11-16-2018, 11:31 PM   #32
LockDoc
The Older Generation
LockDoc's Avatar
Glad you figured that out before digging any deeper......
LockDoc
Leon
Old 11-17-2018, 08:02 PM   #33
68Gold/white
You Do realize now...that any question you ask here, from now on....you WILL get questioned about having gas in your tank...
Old 11-17-2018, 10:19 PM   #34
HIGHWAY BY THE SEA
*SIGH*
Yes, I knew THAT was coming!
But I installed the gauges and got the fuel one working today, so this will never happen again!
Old 11-20-2018, 09:37 AM   #35
Andy4639
Old member
Andy4639's Avatar
Talking Re: Move dash wires = no start
Originally Posted by HIGHWAY BY THE SEA View Post
*SIGH*
You hope!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
