Old 05-18-2004, 12:59 PM   #1
67chevemall
67chevemall's Avatar
What boils over first ?? Who's the chemist
Antifreeze and water OR oil??
Just wondering if your oil boils and burns when the rad goes off smoking like a fiend.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-18-2004, 01:03 PM   #2
sdmahr
sdmahr's Avatar
Definately the water first. I'm not sure about the actual "boiling points" but my guess would be antifreeze second and oil third.
Anybody else?
sdmahr is offline   Reply With Quote
Old 05-18-2004, 01:07 PM   #3
67chevemall
50/ water 50/ Atifreeze
OR
Oil
Old 05-18-2004, 01:11 PM   #4
Jeepster376
Jeepster376's Avatar
Water first @ 212 in open atmosphere but under the pressure determined by your radiator cap and mixed with anti freeze it's higher, like 240. If the pressure is released it's gonna boil right away. Hence the big release of steam, if you get a leak.
Motor oil boiling temps vary by oil types but it's in the range of 400 to 600+ degrees farenheit depending on the specific oil type, so don't expect your oil to boil too soon.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-18-2004, 07:29 PM   #5
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
If your engine is hot enough to burn oil its basically destroyed beyond use.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 05-18-2004, 07:35 PM   #6
atcavage
Wait, oil can be used as a coolant? Maybe I'm just not that truck-smart, but I don't get it. Please help me out.
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 05-18-2004, 07:45 PM   #7
68 Suburban
68 Suburban's Avatar
Oil does not dissipate heat as well as water. Anti-freeze does not dissipate heat as well as plain water either. That is why you should not use more than a 50/50 mix.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-18-2004, 08:15 PM   #8
NPilot1975
NPilot1975's Avatar
I could be wrong, but straight anti-freeze will boil sooner than water. You have to mix it to make it work correctly.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 05-18-2004, 09:54 PM   #9
3intheTree
The three ways heat dissipates from the engine is from coolent, oil and air. Though coolent does the bulk of the work, oil will transfer heat from the hottest parts of the engine (heads) to reletively cool areas. Another reason to check the oil.
3intheTree is offline   Reply With Quote
Old 05-18-2004, 09:59 PM   #10
Jeepster376
Check the what?
Old 05-18-2004, 10:03 PM   #11
Jeepster376
Suzuki has used strickly oil cooling systems in some of their sport bikes.
Old 05-18-2004, 10:30 PM   #12
But most bikes are also designed for Air to do majority of the cooling instead of a liquid coolant.
And if I remember right pure antifreeze boils around 180ish (again why the 50/50 mix), Water 212, and oil depends on the aditives in it, but it's Dang hot.
Old 05-19-2004, 12:05 AM   #13
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Antifreeze contains water pump lubricant and rust inhibitors. Running straight water will get your engine rusty and damage your water pump.
Cat Fuzz is offline   Reply With Quote
Old 05-19-2004, 12:41 AM   #14
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
I'll take a stab at it...
No, in most circumstances your oil does not actually boil when you overheat. Assuming your antifreeze to water ratio is correct and considering the cooling system itself is under pressure, the boiling point of the coolant is well below the boiling point of your average S.A.E. 10W-30 motor oil. I say "most circumstances" because it is possible to boil oil inside an engine, but it's not very probable with even the most exotic automotive engine.
Why? There are a surprising number of factors that prevent boiling, but the first real problems we encounter as we begin to approach the kinds of temperatures required to boil are viscosity and thermal breakdown. This is due, to a large extent, to the high polymer content in multi-viscosity oils. At high temperatures, these polymer additives burn, create nasty deposits, and even trigger a thermal failure of the oil. That's why the general recommendation is to select a multi-viscosity oil with the narrowest acceptable range. In other words, 10W-30 contains fewer polymers than 5W-40 and therefore has a higher tolerance to temperatures outside the norm which is generally considered preferrable.
Let's say, however, that you manage to get around polymer breakdown. Now you've got to contend with the oil's flash point. The flash point is the temp at which an oil gives off vapors that can be ignited. You know those fires they tell you about where grandma's whipping up some fried chicken and burns down the block? A likely culprit is cooking oil heated enough to exceeded the flash temperature which gave off vapors that were then ignited by an open flame.
Most motor oils have a flash point between 400-500 F. When you exceed the flash point of the oil in an engine, you will begin to vaporize the oil itself in the highest temperature regions which, not by coincidence, leaves things such as the piston rings to deal one-on-one with things such as the cylinder wall. This vaporization could be confused with boiling, but it's really quite different. Regardless, it's not likely you'll be maintaining a rotating mass capable of generating the extra 100-200 F required to actually boil the oil in a pressurized crankcase once you've started mashing metal to metal.
I'm sure someone will correct me where I got my facts mixed up. Until then, I'm going to bed since I just realized how much all this typing makes me look like an arrogant ass.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 05-19-2004, 09:10 AM   #15
67chevemall
Shuttermutt! Good Work!
I guess the motor would be toast if the oil boiled!
I just ran the truck toooooooooo! long with no fan(put it in last night thanks summit)
She started steaming! Just wondering if the oil boiled too!
Love that motor u know!
Old 05-19-2004, 11:31 AM   #16
72C203503ONTHETREE
Hope you didnt blow a head gasket or warp anything. What was your gauge reading?
Old 05-19-2004, 11:47 AM   #17
67chevemall
210!
I turned her off and she went to 250!
Then I opened the rad with a big towel and let all the pressure out!
Put the fan in and had her out last night runs great no leaks
Shut her down just in time!
I was trying to rid the winter blues out by heating her up, but let it go to long!
P.S. Fans are good!LOL
