![]() Join Date: Dec 2009
67 (Crew Cab) C30
Here is my Build thread.
The first Picture is of my Grandpa's truck. I loved riding in that truck. These are some of the reasons why I decided to build this Truck. My Daddy also bought a 67 long bed that I drove when I was 10 or 11 years old. I will add to this part of the Story in the future. So I'm building a 1 Ton Chevrolet Crew Cab with small back window with Suburban doors.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 02-27-2019 at 12:18 AM. |
Re: 67 (Crew Cab) C30
I got my sheet-metal this past weekend
from Huey's in Jamestown,TN. More pics. soon.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Moderator
![]() ![]() Join Date: Aug 2011
I have lots of pictures.
I will post. Right now I have the cab removed And getting ready to weld in the floor.
I got Inner and outer rockers ,foot-wells and cab corners also.
Here is a Pic of the Vision ![]() This truck (was) for the most part original. It still has crayon marks on fenders and hood. I found radio delete plate in glove-box.
Here is Pics of taking the cab off the frame.
And then I took it to a Guy close to work that does Sand blasting/Power coating
Looks like a good start, what are you doing for the engine?
My Engine of choice currently is a SBC 350 crate engine.
Cool project but I think The RocknRod was trying to point you to the 67-72 area since your posting in the 60-66 one at moment.
#10 | |
I noticed that after my 2nd post of some pics. Maybe one of the moderators will move it for me.
I'm working on the cab today.
I got a good helper.
Looking good man. I loved my 70 c30 dump truck. I sold it to my buddy so I get to drive it every once and I while.
It looks like you got a pile of work ahead of you. What are the plans of making it a quad cab. Find another cab or suburban to carve up. There's a couple suburbans were I'm at for fairly cheap they would of worked great for your project. |
![]() Join Date: Sep 2015
Looks like a solid start! Keep up the good work.
Thanks.
#15 | |
I will replace the whole front floor pan . Then cut the cab and add rear floor and use sheetmetal from another cab for the roof. I may have a Suburban showing up at Christmas
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 11-27-2018 at 05:06 PM. |
#16 |
![]() Join Date: Mar 2016
Hey Getter-Done, Cool project. looking forward to more photos of your progress. Would it be easier or even possible to cut a suburban body rather than extend a pickup cab? I have never attempted a project like yours so I am just wondering if that is an option.
#17 |
Thanks 62bagger
Yes it can be done either way. Several guys on here Have Great build threads that have done the 2 cab option and also the suburban body. Randy and Trevor was the two builds that was my deciding factor for me to go with a crew cab instead of my original plan of a flatbed truck. I have also been studying a few other members that have built the crew-cab also. I will make my decision if I drag that Suburban home after Christmas.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 07-17-2019 at 01:50 AM. Reason: Suburban deal did not work out. |
#18 |
Subscribe, because I need answer. Lol. I'm having a hard time getting exact information about the frame .
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
#19 |
![]() Join Date: Sep 2007
that's ahelluva flatbed! im subbing for sure. id like to see a4 door 67 small window cab.
1967custom |
#20 | |
My frame is the 157".
#21 | |
I know my plans will change along the way. Both cabs I have are small window. So my plan is Crew Cab with Suburban doors, cab lights and small back window. The rear door will have the same radius (curve) at the top of the door as the truck door. A fleet-side bed with Step-side fenders attached because I plan to keep the dual wheel rear axle.
#22 |
I have been taking pictures for awhile.
So I will post those to get up to my current point of the build as I go. Here is the pics. of the donor bed for my Dually fenders.
#23 |
Here is a picture of the 1st mock up
of one of the fenders.
#24 |
Here is 2nd Mock up
#25 |
![]() Join Date: Jul 2016
I don't think I explained in my build how I made the driver side B pillar from a donor passenger one which I think I bought from Richard too.
Its super easy and is almost identical to the passenger side after cutting and rewelding. Do you remember if I posted about it? Basically I cut the pillar in about 5 sections and flipped them over and to the left then rewelded them together, the 5 sections are all straight when cut and then when flipped they make a mirror image. Inside the B pillar is a hing reinforcing plate, I did the same with it but cut it in 3 section I think. The hinges I just flipped over and drilled one new hole on the door side to match my million piece door. If I didn't post about it, I can do it and number the sections with pictures. The upper half (door frame section) of the B pillar I just used as is, the seam is in the front vs the rear on the other side. Just ask if you have any questions about what I did or what I might have done differently. Sounds like you have a great plan and a good start. |
| Bookmarks |
