Old 11-25-2018, 05:43 PM   #1
jansenjimmy
Power steering pump Bracket
I am putting a 72 blazer back together and can't find info on how the rear section of the power steering Bracket bolts up to the motor. It is a two piece bracket and I think two bolts go in the front of motor and the other goes to the motor mount. I think the Bracket is bent but not sure how I took it off and don't remember this much trouble but it's been a year I am trying to post a pic but I am just beginning to use this forum and have not figured out how yet
jansenjimmy is offline   Reply With Quote
Old 11-25-2018, 09:02 PM   #2
rsavage
rsavage's Avatar
Re: Power steering pump Bracket
Does this help?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 11-25-2018, 09:19 PM   #3
jansenjimmy
Yes. That's it. It must have gotten bent somehow. Doesn't it attach at the motor mount and is there a secret to getting to that boost after the Bracket is installed.
Old 11-26-2018, 11:32 AM   #4
litebulblsc
litebulblsc's Avatar
In his pic, the ear at the top bolt to the motot mount with one of the bolts that hold the motor mount to the engine
litebulblsc is offline   Reply With Quote
Old 11-26-2018, 03:29 PM   #5
rsavage
rsavage's Avatar
Here is another one that shows it mounted on the block. The bolt in my first photo is just holding the two pieces together in the position they would be in. As indicated above, there are two bolts that bolt to the block front and the motor mount bracket part uses the motor mount bolt to fasten it to the side of the block.
1961 C1 Corvette
2021 Durango RT 5.7
Old 11-26-2018, 09:41 PM   #6
jansenjimmy
Thanks for the help.
