Old 05-18-2004, 01:06 PM   #1
John @ BROTHERS
John @ BROTHERS's Avatar
BBC headers for manual trans ???
I have a '69 Chevy with a BBC 396/TH-400 combo. I am changing to a TKO-500 or TKO-600 in the near future and will use the factory linkage. Is anyone running a factory 396/402 with a manual trans and factory linkage with a set of headers? Also, I have airbags so ground clearance is an issue.
1967 Chevy Short/Fleet
1969 Chevy Short/Step
2004.5 Dodge 2500 4x4 Cummins 6spd
John @ BROTHERS is offline   Reply With Quote
Old 05-18-2004, 05:00 PM   #2
gregsplace
gregsplace's Avatar
I use to have a 4-speed/396/headers in my 4x4. I made a "U" shaped peice of 1/4 x 1 1/4 metal strap and welded it to the z-bar frame mount. shortened the z-bar to fit inside that. Dont know if anyone makes headers for a bbc/4speed combo that fits our trucks. My heddmans were supposed to fit manuels , but didnt.
67 3/4 4x4 402,a/t,flat bed
98 GMC Sierra swb daily driver
87 burb parting out.
68 1/2 chevy, 350/350, 71 gmc frame, kid's beater
69 1ton 396-4sp, dump
69 swb stepside 396/400th current frameup
67 swb 454/400th rebuilding now, oldest boy just rolled it
99,HD, Road King Classic
Colwich Ks
gregsplace is offline   Reply With Quote
Old 05-18-2004, 06:02 PM   #3
SCOTI
SCOTI's Avatar
To my knowledge, no such animal exists.
How about using some of the chevelle 3/4 length headers (which are for auto's only) & modify the drivers side to co-exist w/the z-bar & linkage? That would be cheaper than a set built from scratch. Or McCleod (sp?) makes a modular bellhousing that can adapt a hydraulic clutch set-up (& the T-56) possibly allowing the use of the automatic style headers w/o modifying.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-18-2004, 07:15 PM   #4
John @ BROTHERS
I am trying to stay away from a hydraulic clutch setup and the T-56. I have all the factory clutch linkage and am currently working with SpeedDirect on a rod end bearing linkage for big block applications. I know a few customers who are running Sanderson BB3 headers for automatic applications but they will not fit the manual linkage.
Old 05-18-2004, 09:39 PM   #5
fast_dev
fast_dev's Avatar
my hooker super comps fit with a big block and a muncie 4 speed.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 05-18-2004, 09:56 PM   #6
Pont
I need another Barley Pop
Pont's Avatar
My Hooker Comps also fit in my truck without any clearance issues on the drivers side. I did have to do some frame and header mods for the passenger side.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 05-18-2004, 11:35 PM   #7
ts71281
My Flowtech ceramic coated headers fit my big block truck with muncie 4 speed as well........
Joe
ts71281 is offline   Reply With Quote
Old 05-19-2004, 08:05 AM   #8
MOTHERTRUCKERS
Try the DYN86022 Dynamax ceramics, my customers seem very happy with the fit on manual trans trucks.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-19-2004, 11:29 AM   #9
'70_402
'70_402's Avatar
John,...how did you get an avitar after only 3 posts???
'70_402 is offline   Reply With Quote
Old 05-19-2004, 11:33 AM   #10
John @ BROTHERS
I don't know. I tried it and it worked. It must be my lucky day !!!
