Old 11-27-2018, 01:25 PM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Can I start it now?
I am hoping to fire this engine sooner rather than later. Once I have the wiring, fuel, cooling, etc. in place can I start it? My question is, what do I have to have to at least start the motor while the build continues? My thought is once I have the cooling system installed, fuel system installed, stand alone harness installed, battery, etc. I should be able to fire it. I'm a long ways out on having the in cab harness, exhaust, gauges, etc. Hope this make sense on what I am trying to do.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-27-2018, 02:38 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Can I start it now?
Wire, fuel,cool...you can start it if you use the correct wires from the engine harness...you need constant power,switch on power and all the grounds....don't forget the power steering pump...I would advise hooking up some gauges so you can see what's going on..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-27-2018, 03:26 PM   #3
1971Stepside
Almost Satisfied
Sounds as simple as I was thinking. Just wanted to make sure there wasn't a gotcha in there that I needed to be aware of.
Old 11-27-2018, 03:51 PM   #4
mongocanfly
Has your ecm been flashed?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-27-2018, 04:03 PM   #5
1971Stepside
Almost Satisfied
At the moment no, but I will have it flashed to remove the VATs etc. and then once I am able to dyno the truck I will take it to them to set it up correctly. I just want to be able to keep the oil flowing over the next 18-24 months...or, until I hit the powerball.
Old 11-28-2018, 10:00 AM   #6
Jstock85
You'll probably need to connect the air system as well. I believe The PCM will need the MAF. Others on here may correct me.
Jstock85 is offline   Reply With Quote
Old 11-28-2018, 10:14 AM   #7
ls1nova71
ls1nova71's Avatar
Turn the VATS off, hook up the harness and fuel system and it will start. I start them on the garage floor all the time this way. Take the belt off so power steering fluid doesn't go all over though. You dont need coolant if you aren't going to let it run for very long.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-28-2018, 11:53 AM   #8
1971Stepside
Almost Satisfied
Thanks guys. I will have power steering hooked up, but not the prop valve. I shouldn't get the squirts if no pedal is applied.
Old 11-29-2018, 11:14 AM   #9
paul mora
Trans lines?
Pulatoy
paul mora is offline   Reply With Quote
Old 11-29-2018, 06:07 PM   #10
1971Stepside
Almost Satisfied
Yes, I will have trans line hooked up to the radiator before turning it over.
Old 12-02-2018, 10:55 AM   #11
davepl
davepl's Avatar
Spark, fuel, and compression, that's all you need (and to get that, proper harness connections to the LS ECM). If you want to RUN the thing then finish it properly, don't be in a rush. But if you just want to fire it up for a few seconds, you can do that without cooling. Heck you can do it without exhaust.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
