#76 |
The Older Generation
Re: The Burb a long time coming
Man, you are doing some serious mods to that thing. As much as I like cutting, fitting, welding, and turning wrenches I don't think I would tackle something like that. Good job! LockDoc
#77 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Very nice!!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#78 |
Coordinator of Synchronicity
![]() Join Date: Dec 2005
Chassis crated up and ready go ... all 20 feet
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be |
#79 |
My goodness ...
#80 |
![]() Join Date: Jul 2012
Really crated up! When will it arrive?
#81 |
probably monday. weather permitting
#82 |
Well here are the shots prior to body test fit
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be Last edited by LockDoc; 10-24-2018 at 07:29 PM. |
#83 |
Flipped the picture for you. Looks good! LockDoc
#84 |
thanks ... fingers crossed
#85 |
Here are some pictures of the body on the chassis
#86 |
And it on little 14" wheels for moving around the shop
#87 |
Now the question is ... do ya think I can get a 177 compressor and a Sniper EFI on top of it and still use a stock hood to hide it?
#88 | |
I can't help you there, but it's looking good, that's for sure... ![]() LockDoc
#89 |
![]() Join Date: Sep 2018
Looks good !!!!
#90 |
Nice work!
Making serious progress!!
#91 |
Body mounts were off ... But Mo's took care of it ...now they need to work on trans and shaft tunnel it was a low and now needs to be cut and slightly modified so the yoke is clear and then get a "single" drive shaft made for it
#92 |
All settled in place but need some clearence Doug said he will make it a high hump and add just a little height to the stock raised portion down center
#93 |
Body and chassis seem very tight now and once the rear wood is installed the body movement thanks to the poly will be zero
#94 |
![]() Join Date: Jan 2004
#95 |
Made one of the many big decisions on the project ... The Wheels
Going to run 20" all the way around and have chosen a BOZE wheel called "Traction" for the front and "Traction Concave" for the rear, now I need to decide on whether to color match or leave polished
#96 |
can't wait to get the 20" wheels on to see the stance better
14" wheels aren't doing it for me
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be Last edited by Burb; 01-21-2019 at 12:47 PM. |
#97 |
A Fresh slate ... with the wheels, smooth bumpers, mirrors and grille modes applied...
#98 |
Well it is time to get my ideas and vision visible for the build
And I have happened across a fantastic digital rendering specialist that I am sure has been used by others on this site ... considering his work Give him your ideas and he quotes you off of that ...simple.
#99 |
bit by bit ...
#100 |
A good direction you are taking the Burb. Will look sweet!
Tags |
1971 suburban, build thread, chassis swap, frame off, resto |
