Old 11-30-2018, 12:57 AM   #10
Mike C
Mike C's Avatar
Re: Thinking of swapping transmissions
Originally Posted by Stephen717 View Post
OK, the plan is building the 454 that was in my old work truck, adding a 12 bolt posi rear from a chevelle, and I am scrapping the idea of rebuilding a used transmission as I found https://www.5speeds.com/ this guy sells brand new muncie 4 speeds and has the m22x I'm looking for. I have heard of the np435 but don't know if I would go that route
The NP435 is a close(r) ratio truck 4 speed. But it is still a big honking, slow shifting, truck 4 speed. It just has less first gear than some of the other big honkin' truck 4 speeds which are great in a truck that is used offroad or for hauling big loads.
If you are building a hot rod, get a hot rod transmission. You will not regret buying from Jody's Transmissions as you will probably have some questions and his support is second to none. The AutoGear trans quality appears excellent. I'm helping a guy swap one into a big block Camaro and Jody has been a great resource.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
