Surge tank location
Hi all.
It's been a long time since I've visited the site and my truck has been neglected the while time .. I'm getting back to it now and have picked up a basic Sniper kit on Black Friday at a slight discount. I'm going to keep the in-cab tank and mechanical fuel pump to feed a surge tank, but have yet to come up with a location for the surge tank. Has anyone installed a surge tank in an out-of-the-way location? My truck is a 67 Fleetside with a small block. Thanks for any info/pics! HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone ![]() |
Re: Surge tank location
I put mine next to radiator on drivers side. Made brackets to attached to core support.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
This is the sump that I used Edelbrock 3605. Their brackets would not work so I made my own. Was a tight fit but it works great.
https://images-na.ssl-images-amazon....L._SL1500_.jpg
That looks good.
Are you running a return line back to your tank? I have a Flex-A-Fit radiator with the heat sinks on the tanks. I may make a bracket to work with whatever surge tank I go with.
No return with this set up.
I put my surge tank behind the cab under the bed floor. It’s fixed to some brackets which are bolted to the chassis rail. A low pressure pump feeds the surge tank which supplies the efi. From there the fuel returns back to the surge tank which also has a return back to the in standard in cab tank.
I can run the the truck down to near empty and I’ve never had any fuel starvation. It works great.
John 69 c20, 396, th400, dana60, ps, ac |
laying low
![]() Join Date: Mar 2001
turn
