11-29-2018, 06:41 PM | #1 |
C30 LS engine mounts easiest route
I’m installing a 6.0/4l80e combo into a 1974 c30. I’ve been doing research but can’t find the cheapest and easiest route. This isn’t my first LS install, last time I welded eBay mounts in my 56 3100. Had the engine in and out 3 times.
On this install I’d like to bolt up premade type. Can I use the standard plates and reuse my clamshell type mounts? I need some good advice, you guys know way more than me! Thanks Posted via Mobile Device |
11-29-2018, 07:04 PM | #2 |
Re: C30 LS engine mounts easiest route
Different yr but I just used the eBay stock location adapter plates and clamshells...dropped right in..
12-01-2018, 10:35 AM | #3 |
I’m on it! Thanks again.
12-04-2018, 10:43 AM | #4 |
Mine is a 72, but have replaced the frame mounts with newer stock ones from a squareboby. I used dirty dingo sliders for the same vintage, they dropped right in, and you have 2 inches of forward backward movement. I see that you want to keep the stock clamshells but these worked really slick for me.
