Old 12-04-2018, 04:51 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
My Pet Peeve.. Short Rant
Saw this truck on EBay this morning and looking over this morning and thought wow a decent driver Cheyenne Super that is pretty original.. Scrolling the multiple pics I come to the under hood shot and horror as usual all the A/C stuff is gone. Why do people do that ????
https://www.ebay.com/itm/1972-Chevro...53.m1438.l2649
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 12-04-2018, 04:58 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
Re: My Pet Peeve.. Short Rant
Wow nice clean truck, yes your right. why? I mean it wouldn't take much more to go a little further and put the A/C stuff back right...
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 12-04-2018, 05:14 PM   #3
Coley
Coley's Avatar
Smile Re: My Pet Peeve.. Short Rant
Well, it looks like has a non-stock (replaced) motor...fair enough.
So if a shop was doing the work for the owner they might have said that it is just as easy to remove the non-working A/C stuff, while replacing the motor... and leave it off than the extra cost of hooking it back up and charging, etc.
The owner probably got it all back in a box...and that was the end of it.
As well tho', why would they go change the interior from a nice parchment to what appears to be re-dyed black, at least on the door panels, etc.
I like those original parchment interiors and I think they work well with the Ochre color....just my thoughts.
...nice example tho'...and still a good price so far for sure.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 12-04-2018, 05:17 PM   #4
leddzepp
Moderator
leddzepp's Avatar
“AC works, just needs a recharge....and a compressor, condenser, expansion valve, hoses,....”
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-04-2018, 08:04 PM   #5
clay68c10
clay68c10's Avatar
Because it's easier and cheaper to do a hack job than a real repair. Add the fact that most amateurs have no understanding how a/c works and what it takes to repair it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-04-2018, 11:27 PM   #6
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
When I worked as a mechanic, I could pull the AC out of the way for engine R&R without even discharging the system. I guess a lot of guys don't care about not costing the customer extra money, or maybe they just don't know any better. It doesn't even require knowing how to fix it to move it out of the way for the other work!
Back in the '70s I was asked to go and troubleshoot a brake problem in the field. The "mechanic" was replacing a steel brake line using vacuum line with clamps, and couldn't figure out why the hose blew off when he stepped on the brake pedal. I kid you not.
~Steven
Simi Valley, CA
Old 12-04-2018, 11:41 PM   #7
jocko
jocko's Avatar
When I was younger, I never cared about a/c. Then I moved to China Lake.
Old 12-05-2018, 12:50 AM   #8
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I did exactly that when I R&R'd the engine in my project truck some 25 years ago. Turns out I managed to keep all the A/C parts less a few retainers and bolts, which I swiped from my other truck. It's one reason I bought the truck
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-05-2018, 02:13 AM   #9
kwmech
Bingo! Adding to that is the fact that if you repair it correctly at shop price, it could run over a grand easy. I converted my 69 to a big block and the AC to R4 with a short water pump. I'll post up some pics when I finish it and get it charged up
Old 12-05-2018, 10:42 AM   #10
volksworld
cause its a truck...its job was to go from point a to point b with a load of stuff in the bed...when the a/c broke you rolled down the windows cause you couldnt afford to fix it....and the minute you did anything to the engine that required removing the compressor you left it off so the truck would be easier to fix in the future...that system could have been removed 40 yrs ago
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 12-05-2018, 10:54 AM   #11
HO455
HO455's Avatar
Its also entirely possible that it was removed in 1982 when the price of fuel had jumped and the A/C had died and the owner decided he could save some gas by removing it.
I tore the A/C out of my 68 396 SS Chevelle in about 1984. It didn't work and was in the way just about every time I was under the hood. I was happy to lose 50 pounds of dead weight. Not saying I would do that today.
RIP Bob Parks.
Old 12-05-2018, 11:14 AM   #12
davepl
davepl's Avatar
Because people believe that a cleaned up engine compartment with the non-working AC removed will fetch more than a AC truck sold as incomplete or non-working.
So far as I'm concerned, that makes them a heater truck with the wrong interior and HVAC box!
Plus, fixing AC is hard and removing it is easy.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-05-2018, 11:15 AM   #13
davepl
davepl's Avatar
Second owner. No original owner would save up the $750 (in 1970 money) to splurge on AC and then leave it non-operational.
Non-working AC is strictly a used car phenomenon.
Old 12-06-2018, 10:29 AM   #14
liftlawssuck
liftlawssuck's Avatar
I know why I remove them. Ugly as heck. Being in New England it's not really needed. Got a 69 Camaro....yup pulled it out too. Still have it and could go back on any time. Got a 79 K10 Silverado....yup pulled it out too. Know how hard it is to find a cab from out west that doesn't have AC!! Took a while but I found one. I like the clean look and to me AC is the best way to ugly up an engine compartment. I want a truck. Not a truck that has car options. This place would shred me for I did to my 79. It is a Silverado but I basically made it what I want and that's prolly equal to a Custom Deluxe now. I just wish I could buy a new truck without any of the crap they have in them now. Ok my rant over. Lol.
liftlawssuck is offline   Reply With Quote
Old 12-06-2018, 11:37 AM   #15
morepwr
I pulled my A/C out.....and replaced it with a Vintage air unit! Cleaned up the firewall and a smaller compressor on the engine looks cleaner.
morepwr is offline   Reply With Quote
Old 12-06-2018, 11:53 AM   #16
67ChevyRedneck
67ChevyRedneck's Avatar
Given the location, they probably didn't care about the expense of making the A/C work.
Unfortunately, the firewall between A/C and non A/C are a bit different, so you can't just pull the big A/C box and put on a factory heat box to make it "look" better.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-06-2018, 12:09 PM   #17
Nothing wrong with pulling a compressor and lines on a truck you bought with it not working in. It's never a first concern and it's in the way. I always do that, plug the fittings, store the parts removed. But why it's gone is because there was a point in the middle of a truck's life it was just an old truck that still ran and most people don't know how to deal with a/c... even those who are mechanical and do about anything else on their vehicles. Many can do everything but repair hvac, carbs, and automatic transmissions. Why it's missing is because that's what most Americans do. Throw stuff out, don't see the value till it's hard to find.
This doesn't stop me from buying a truck. It just means here we go again, start searching for the parts
Old 12-06-2018, 01:20 PM   #18
demian5
demian5's Avatar
One of my friends has his grandmas "original owner" 69 chevelle malibu with 350/350. At one time in the 80s, he and his friend put a performer intake, carb and headers on it and **** canned the AC stuff. however, luckilly, it was all put in a plastic bin and kept in the garage...
But why?
We are going to get the AC going with one of those sander compressor/condenser/electronic poa valve conversion kits.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 12-06-2018, 05:27 PM   #19
Already Gone
Thanks for all the replies. You all have valid comments and yes over 47 yearsa truck would go through multiole stages. I guess my thoughts are if it stopped working remove the belt and leave it intact so someday if you want to repair it everything is there. Just an old guys rant.
Old 12-14-2018, 11:51 AM   #20
cardude
cardude's Avatar
My AC doesn't work presently; but I still run the belt to keep the tension on the water pump even from both sides of the engine. (Big Block)
cardude is offline   Reply With Quote
Old 12-14-2018, 12:32 PM   #21
Jake Spoon
I do a lot of shopping for vintage automobiles and it seems more often than not the A/C has been removed. If it's still there, it's usually not working. As a general rule, since I'm in Texas, I factor an additional $2K to any vehicle purchase for Vintage Air.
Jake Spoon is offline   Reply With Quote
Old 12-14-2018, 09:33 PM   #22
TBONE1964
Cluster King
TBONE1964's Avatar
I have never in my life seen such a failed experiment as to how the engineers plumbed AC onto one of these trucks. It looks like when they were in development stage (something I know a lot about) they just could not get it packaged right and just threw it were it landed and called it AC.
And that is why most of mine got canned. I just could not stand to look at that mess of crap under the hood. Now the only reason I would have one on a 67-72 is if it was there when I bought it and functional.
Let the stone throwing begin!!!
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
