Old 12-05-2018, 07:43 PM   #1
scott123
2003 6.0
Just looking into my first LS swap. Exploring some options.
Is a 2003 6.0 out of a 2500HD a good option?
Are the stock heads a good choice?
Cam upgrade readily available?
Any input will be greatly appreciated.
S
scott123 is offline   Reply With Quote
Old 12-05-2018, 09:38 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 2003 6.0
That should be a lq4...great engines...about 322hp stock...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-06-2018, 09:26 AM   #3
StingRay
StingRay's Avatar
Re: 2003 6.0
That's the engine I have for my swap. A very good choice. Heads are 317's and are very good flowing but have larger chambers (as do all of the LQ4's and LQ9's) so only 9:1 compression. LQ9's have different pistons and half a point more compression.Tons of cams available. The 04 switched up to floating wrist pins which is a bit better for performance and longevity. 03 fuel rails are set up for a return line so if you go returnless you will have to block one or swap in 04 rails and cross over. If you can find a later 6.0 with the LS3 heads you'd be ahead of the game. LS3/L92 heads swap onto LQ4/LQ9 engines so you can go that route later for a performance upgrade.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 12-06-2018, 10:27 AM   #4
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 2003 6.0
I have an 03 LQ4. Mine is not a return fuel line set up. Came out of a Yukon Denali. Interesting...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-06-2018, 11:22 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 2003 6.0
^03-04.5 is the changeover period, and it was a rolling change through 04 between the light, medium, and fleet duty trucks. Some 03's were return style yet had DBW, others were returnless, and some were return with cable throttle.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-06-2018, 12:11 PM   #6
Rich84
Rich84's Avatar
Re: 2003 6.0
One of mine is an '04 returnless with cable..Seems like they got every combo covered.lol
Rich84 is offline   Reply With Quote
Old 12-06-2018, 03:06 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 2003 6.0
and lets not forget the flex fuel trucks and those combos..
Old 12-08-2018, 12:39 AM   #8
beaterku
beaterku's Avatar
Re: 2003 6.0
I’m installing an 03 LQ4 in mine right now. Stock bottom end with milled and cnc’d 317 heads.
beaterku is offline   Reply With Quote
