Old 12-07-2018, 01:20 AM   #1
Hizoot
Hizoot's Avatar
Fitting Ridler or Boss wheels
Hello All,
I have a 1974 step side & I'd like to replace my 8" x 18" rear wheels with 9.5" x 18" Ridler 695's or Boss 338's. I've done the math (back space, offset) but don't trust math alone (long story) sooo has anyone hung these puppies under their fat fenders & if so any problems..?
Thanks !
Hizoot is offline   Reply With Quote
Old 12-07-2018, 12:53 PM   #2
SCOTI
SCOTI's Avatar
Re: Fitting Ridler or Boss wheels
Originally Posted by Hizoot View Post
Hello All,
Thanks !
Don't just trust the math. You already have 8"w 18" wheels right? Put a 2x4 on the inside (or outside) & see where or if interference occurs. Adjust your dimensions according to the tape measure.
Other peoples trucks can possibly have a different set-up vs yours. I would only trust 'blind' recommendations if I could swap their combo over for validation of fit/clearances before spending the money.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-07-2018, 12:58 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Also don't compare wheels on a fleetside truck to your stepside.
Like SCOTI said,... do the measuring yourself.
Look at this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=530806
Keith
Convert to disc brakes.
Old 12-08-2018, 02:16 AM   #4
Hizoot
Hizoot's Avatar
Gents,
I apologize I didn't communicate better to you & I thank you for your good advice & the handy links you sent, I appreciate it. However when I said "I've done the math" that also means I've taken the measurements etc. By all accounts it should work but will be close. Since so many people come & go from this forum, I thought maybe someone might have done this set up before & could share their experience before I commit & plunk down the $$$. I promise not to compare mine to a fleetside or anything else.
Thanks for your help..!
Old 12-08-2018, 12:09 PM   #5
skyphix
One thing that will help is posting your tire width and overall height you'll be running. I know I've run 31x10.5 on my lowered (unknown flip kit but appears to be about 6" in the rear) fleet side with 4" back spacing on an 8" wheel which should be about like 4.75" back spacing on a 9.5 wheel.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 12-09-2018, 09:44 PM   #6
Blackmetal86
I think boss is out of business so you may have trouble getting them in correct offset etc
Blackmetal86 is offline   Reply With Quote
Old 12-10-2018, 10:42 AM   #7
riz
BOSS IS out of business....... go with the Ridlers.
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
