Old 12-09-2018, 05:54 AM   #1
tino0217
No reverse lights
I just changed both flashers on my 71 C10 blinkers are working hazards of working horn isn't working and reverse lights aren't working anybody got any tips
tino0217 is offline   Reply With Quote
Old 12-09-2018, 10:22 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: No reverse lights
I wouldn't swear to it but I don't believe the flashers have anything to do with reverse lights. Maybe it's the NSS on the steering column.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-09-2018, 11:20 AM   #3
davepl
davepl's Avatar
Check the switch on the column. It should bring the reverse line hot at some point through the sweep of the needle, find out where it is and if it works!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-09-2018, 01:49 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
IIRC, it's on top of the steering column, near the firewall.
- Mike -
RIP El Jay
Old 12-09-2018, 02:24 PM   #5
hugger6933
I concur but keep in mind the NSS is two switches and the purple wires will be the starter side the other lighter wires will be the back up lights. make sure the tang isnt broke off or check and see if the truck will turn over in say reverse [but do that safely] and it may be the switch or adjustment
hugger6933 is online now   Reply With Quote
Old 12-09-2018, 02:27 PM   #6
68gmsee
Active Member
68gmsee's Avatar
I just went through that on my 68. It was the switch on the steering column bottom closer to the inside firewall. If it's automatic, you may be able to locate the switch in local auto parts but if it's a three speed column shift, you'll probably have to order it like I did.
First thing to do is to try to adjust the switch by loosening the two small screws and moving it one way or the other. Make sure the truck is in reverse and the key to the on position when adjusting. Helps if you have someone behind to let you know if they come on.
Next, check the voltage to the connector with the key on to see if you have 12vdc.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 12-09-2018, 02:46 PM   #7
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Not to hijack, but where is the reverse light switch on a 4 speed granny gear? I also have no reverse lights.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 12-09-2018, 04:27 PM   #8
Noah96
Same problem all my lights work except reverse I have replaced all bulbs and rear wiring. Anyone have a picture of a NSS mounted in a 4spd truck?
Noah96 is offline   Reply With Quote
Old 12-09-2018, 11:53 PM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
Highway:
On the SM465* 4 Speed the Reverse Switch is mounted high in the ''neck'' of the tranny on the left or Driver's Side. If it's not a hassle to pull the hump cover, it's right there. If that's not convenient, crawl under the rig and feel your way up the side.Two terminals in a rubber plug run to there. If it's dislodged, reattach it. The switch is a replaceable item if FUBAR.
* The SM420 is similar if not the same. But since the shift lever goes to the left instead of right when selecting reverse, it could be on the opposite side. I'm not expert on the 420. Their last model year was 1967.
Noah:
Neutral Safety Switches are not present on manually-equipped trucks. It's possible for an originally automatic truck that was converted to manual to still have the NSS on the harness. This is a rare conversion, the trend usually goes the other way.
Old 12-10-2018, 04:00 PM   #10
cleszkie
cleszkie's Avatar
Are you blowing the reverse lamp fuse? If so, then your reverse switch on the tranny is probably working and you have a direct short somewhere (insulation worn off wire and grounding out). If you are not blowing fuses, you might have a bad switch OR bad grounds. I'd go after the low hanging fruit first and check all your grounds for the reverse lamps.
cleszkie is offline   Reply With Quote
Old 12-10-2018, 05:20 PM   #11
rockyrivermark
first check to see if you have power at the reserve light socket. If so there is a grounding issue or problem with the bulb socket.
If no power at the bulb then replace the neutral safety switch since it also activates reverse lights.
The NSS can slide on the small 5/16" screws and will need adjusted to your Reverse selector.
RRM
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
