Old 12-15-2018, 11:05 AM   #1
NewBayColony
NewBayColony's Avatar
Firewall Plug Connectors
Is there a source for the Male (Engine Side) wire connectors within the main firewall plug? I have two that are deteriorating. Thanks!
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 12-15-2018, 12:01 PM   #2
davepl
davepl's Avatar
Re: Firewall Plug Connectors
I replaced mine with a junkyard block replacing each fuse terminal pin for pin, turned out nice because I found a like-new one. But I've not seen them sold separately, unfortunately.
I don't know for sure but I bet if you called M&H or similar where they MAKE the harnesses, they might be able to hook you up with the connector for one end.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-15-2018, 12:11 PM   #3
HO455
HO455's Avatar
They are available through NAPA (#725444 for 14AWG) and other sources. Known as Packard 56 or GM 56 connector pins. They come in different wire sizes. I have some information posted in my WMB thread (link below) from when I replaced one of the pins in my connector.
http://67-72chevytrucks.com/vboard/s...698377&page=16
RIP Bob Parks.
Old 12-15-2018, 01:38 PM   #4
NewBayColony
Thanks!!!
72 C20 292 3OTT
