![]() Join Date: May 2011
Parting newer NP 205 with slide in tail shaft
Bought this to get the square front driveline yoke so decided to part the rest. Tranny adapter was already gone also no shifter or bolt.
Tail housing 35 plus shipping Rectangle cover plate 18 shipped Round cover plate 24 shipped Shift rod plate 18 shipped If there is anything else you need let me know with zip and I can get you a quote shipped. |
Re: Parting newer NP 205 with slide in tail shaft
speedometer drive? picture?
I will get you one tomorrow.
Here you go
ttt
ttt
Truckin' Krazy
![]() Join Date: May 2000
I'll take the tail housing, & does that include the piece the speedo housing is screwed into? Also looking at the pics it looks like some of the reinforcement fins are broke off, just want to make sure the housing isn't cracked & last ? was this attached to a turbo 400?
Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
#8 | |
One of the First
![]() Join Date: Jan 2000
I need the bolts that hold the outer plates. I bought one in peices, no hardware for re assembly. Thanks
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#11 | |
You were right 2 fins are broke but no cracks the truck was on its side when I removed the transfer case so I'm guessing fork lift damage
Just read your post again it doesn't include the piece the speedo is screwed into but I will sell that also for 35 but the speedo drive has already been removed. It will all fit in a medium flat rate for 13. Let me know if still interested.
35 tail housing 35 rear bear retainer housing 13 shipping |
Ttt
#15 |
is this a round or figure eight case? if its a round case would you consider selling the case itself?
69 custom camper special 4x4 1969 K5 blazer 1972 short step 4wd factory air gmc |
#16 |
#17 |
Ttt
#18 |
One of the First
Still need the bolts that hold the outer plates. I bought one in peices, no hardware for re assembly. Do you have anymore?
#19 |
Assuming newer means a round pattern input side, don't scrap the case. NV4500 swappers want it. Hell, I might buy what remains after parting...
#20 |
No, newer means 73 up has the slide in yoke (no sure when the slide in yoke came out but post 72) at the rear still come off a 350 turbo so doesn't have the round flange.
#21 |
All about them K’s
![]() Join Date: Jun 2014
Tail shaft was from an Early 80s-early 90s 1 ton reg cab if I recall correctly. Im curious to know if this in fact had a t350 in front of it. I would have figured a 400 or 465.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 03-31-2017 at 09:37 AM. |
#22 |
It had a 350 adapter on it when I bought it and I know my brother-in-law had one behind a 350 turbo years ago that he used for 4 wheeling. Actually he may have one still laying around if so I will get a picture.
#23 |
Ttt
#24 |
I think all NP205/adapter mating went to round no matter which transmission. Transmission has nothing to do with the output end. My buddy had a '79 K/20 (bought new) that had a NP205/TH350/manual hubs.
| Bookmarks |
