05-16-2004, 09:05 PM | #1 |
weight
Hi guys, Does anyone have any idea what a burb tub with only the third door weighs interior is striped tub is pretty solid let me know.
Thanks EMMETT
Kaukauna WI Airplaines don't land here they are sucked down |
05-19-2004, 12:11 AM | #2 |
Tub
Ok did any one lift a striped burb cab if by man power how many men? If with a cherry picker how did it work, I am just trying to figure out if my trailer will hall it about 400 miles. Or has anyone halled one and on what kind of trailer? I have a older double wide snowmobile trailer the frame has ben beefed up the axel is rear axel from a dodge carrivan with 14" wheels it can handel a pretty good load, I would guess a C-20 cab at about 300lbs stripped, I cut mine into three pieces and loaded it on the trailer by my self I am guessing a burb would be about 2.5 to 3 times more. Any input would realy be appreciated.
Thanks In Advance EMMETT
05-19-2004, 06:30 AM | #3 |
I used an engine hoist attached in the rear door opening to lift rear and an "A" frame with chain hoist to lift front. Mine had all doors and glass, I figured 1000-1500 lbs.
'72 4x4 Blazer (in the works) |
05-20-2004, 03:01 AM | #4 |
Thanks Texsparks Thats pretty close to what I was guessing my trailer will handle that nicely.
Thanks Again EMMETT
