Old 12-19-2018, 05:01 AM   #1626
RockinKees
RockinKees's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
Doug, you’ll be ready before the Wire and Fire
Then you’ll have a party with the boys.....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-19-2018, 08:58 PM   #1627
Advanced Design
Advanced Design's Avatar
Originally Posted by joedoh View Post
gonna get it done before the wire and fire and everyone will just drink "antifreeze"
*joedohs super antifreeze recipe
ice in highball glass
2 jiggers stoli vodka
2 oz tonic
fill with jarritos lime soda
squeeze lime wedge
no kidding, its awesome. getting ready for the christmas party!
I want to see that holley setup installed in an AD, I like it lots.
A sip of the antifreeze would keep me from freezing up for sure! Once we have a start, we will dry fit the front and have the accy drive installed to check space to rad.
Advanced Design is offline   Reply With Quote
Old 12-19-2018, 09:00 PM   #1628
Advanced Design
Yeah, lot of help getting ready.
Non FB live right now on some prep work...if I get off the seat.
Old 12-20-2018, 09:37 AM   #1629
Advanced Design
A few posts ago we were looking at accessory drive dimensions with concern to radiator clearance. Moving the engine back solved that more than likely. Image on the left is before and image on right is after moving it back, noticeable comparing balancer to crossmember.
And I likely gave myself another clearance issue with the intake. Adding the throttle body and intake tube shows contact with radiator, fan, shroud likely. Will know more when more pieces are put in place...again. Have three ideas to resolve that potential issue.
Old 12-20-2018, 09:51 AM   #1630
Advanced Design
The wiring is coming along neatly.
Old 12-20-2018, 05:00 PM   #1631
RockinKees
RockinKees's Avatar
Wiring looks nice!
You gained an inch or so with putting the engine back?
Cheers!! Kees.
Kool Guyz CC
Old 12-20-2018, 10:44 PM   #1632
Advanced Design
Wiring looks nice!
Thanks, he does nice work. Yes I gained about an inch or so moving the engine back so water pump tip to radiator fan clearance should be good. Going to put front end together, probably at our Wire and Fire, to check spacing.
Old 12-20-2018, 11:08 PM   #1633
Scott2
Great start!
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 12-20-2018, 11:45 PM   #1634
smbrouss70
smbrouss70's Avatar
I love nice, neat wiring. Looks good.
I wish I could make the wire & fire, maybe you could stream a live broadcast for those of us that can't make it.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-21-2018, 09:29 PM   #1635
Advanced Design
Originally Posted by Scott2 View Post
Great start!
Thanks Scott!
It would be cool if you could make it up! Streaming would be interesting....hmm..I am intellectually challenged in knowing how and for sure band width limited out here.
Brake plumbing parts and some other stuff showed up.
Old 12-22-2018, 10:20 AM   #1636
reaper71
reaper71's Avatar
Um Doug....How many wheels you running on this thing?
I see 12 braided lines to go from calipers/wheel cylinders to hard line.
reaper71 is offline   Reply With Quote
Old 12-22-2018, 11:37 PM   #1637
Advanced Design
Good eye Mark! To make sure we have good fitment for our Wire and Fire, I purchased a set in 14”, 16”, and 18”. That gives us some flexibility to determine what works best. One of my pet peeves is not having the needed parts when building. Living here in the sticks that issue always delays me a week, so I tend to order enough to make sure it doesn’t happen.
T shirts are done and I will pick them up next week. Be cool if you and Jim could make it Mark.
Old 12-22-2018, 11:40 PM   #1638
mongocanfly
mongocanfly's Avatar
Doug ...you must have been a boy scout...always prepared...do you have a flare tool for your hard brake lines?...I've got a Eastwood one if you have a need for it
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-22-2018, 11:50 PM   #1639
Scott2
I’m looking forward to the Wire and Fire -
I think it’ll be a great event! And t-shirts!
Scott
______________
Old 12-23-2018, 12:00 AM   #1640
Advanced Design
Thank you Greg! No Boy Scout, just grew up on a farm in the sticks where we had to be somewhat self sufficient. Guess those boyhood lessons stuck with me.
If you are able to make it up, please bring your Eastwood one along. It would be interesting to compare it to the Mastercool hydraulic flaring tool I have. We are in good shape with benders too. We all dislike crappy benders and we loaded up with each size of a high quality bender from Gulley performance.
For fuel lines we have the design pencilled out, Nathan bought a big quantity of fittings from Jegs, we have the flexible line, and will have straight tube to give us options too. My Christmas present to myself a couple years ago was the Cool Tools fitting press so we have that. And we will also have the homemade one Nathan put together for comparison purposes.
This is going to be fun.
Old 12-23-2018, 12:07 AM   #1641
mongocanfly
This is the one I have...a hotrod buddy talked me into it...it works great....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-23-2018, 12:13 AM   #1642
Advanced Design
Yes! So glad you are coming Scott. T-shirts for sale with 100% going to hospice. Lunch, non alcoholic drinks and snacks provided. A raffle for hospice fundraising with some good prizes ,...and there will be some prizes that will be difficult to carry on a flight.
Guys, out of great respect for those that are investing their money, time and effort to be here and to honor my wife, please know my family, friends and I are doing all we can to make sure we have a fun, safe, productive and really enjoyable event. Some of the hospice folks will be here too.
Now if the weather will cooperate...
Old 12-23-2018, 12:16 AM   #1643
Advanced Design
Those look pretty slick! They weren’t out when I bought the Mastercool.
Old 12-23-2018, 03:09 AM   #1644
joedoh
joedoh's Avatar
hahaha holy shoot. I have no idea why this struck me as funny, probably because I have MADE three trips for the same parts in the past I have been thinking about it the wrong way! why fight? make one trip and buy three times as much, no matter how you slice it, its more efficient!
Old 12-24-2018, 06:12 AM   #1645
RockinKees
RockinKees's Avatar
It’s going to be an awesome event, too bad I can’t be there...
It’s like living on an island
I have worked on Curacao for several years, there did we have the same problems with parts, everything had to flown in or make it yourself if possible.
But you tackled these problems
I’m in for a livestream, I always watch Dragracing on livestream, works perfect!!
You can do a livestream on FB or YouTube maybe? If you do, please let me know?
Merry Christmas everybody!!
Cheers!! Kees.
Kool Guyz CC
Old 12-24-2018, 05:50 PM   #1646
Advanced Design
Sorry Kees. We are internet deficient here. Shop has no internet and a cell phone has zero signal inside the building. Sometimes you can get a 3G signal in the shop driveway if you stand in the right spot...so I don’t think that will help.
Roughing in the LS wires and mounting components under the seat. Using the stripped down original harness and modifying to fit rather than buying a new one due to the placement of the PCM, TAC module and harness fuse box here.
Old 12-24-2018, 07:20 PM   #1647
RockinKees
RockinKees's Avatar
No problem at all Doug, but it would have been nice ;-)
Wish I could be there with you and meet all of you, but as always, money is in the way...
I know you have a good time, I see the pics afterwards and have a laugh with you!!
Merry Christmas!!
Cheers!! Kees.
Kool Guyz CC
Old 12-24-2018, 08:58 PM   #1648
mongocanfly
Doug...if you keep up this pace there won't be anything left to do at the Jan 19 wire/fire except give people joy rides in the burb..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-24-2018, 11:48 PM   #1649
Advanced Design
Merry Christmas!!
Yeah I wish you could make it. At least we can share pictures and the stories here. Merry Christmas!
well we will still have wiring to do for start, then sequence in brake lines, air ride stuff, accessory drive and front end assembly to check for radiator clearance...especially with my choice for intake manifold that looks like will put the air tube right through the grill. Plus a good amount of old fashioned bench racing with good folks.
And I might have to rethink the line connection to the caliper. It looks like this will put too much stress on the aluminum.
Old 12-25-2018, 09:14 AM   #1650
reaper71
reaper71's Avatar
Banjo bolt style Doug.
