Old 12-20-2018, 02:12 PM   #1
RustyPile
RustyPile's Avatar
Re: I need a new carb for a 72 292
Originally Posted by Tiiimmmaaayyy View Post
No, just the stock one barrel manifold. I haven't really kept track of the gas mileage yet since I just replaced the severely leaky carb and all the other stuff that was screwing up engine efficiency. All I know for sure at this point is that I don't have to put $20 of gas in it every day anymore.
I'm confused??? Your amazon link took me to a Toyota Landcruiser carburetor.. It's definitely a progressive 2 bbl model.. Description says manual choke but the pictures show an electric choke stove..
If you actually have that carburetor, you'll need an adaptor plate to install it.. But --- You say the replacement carburetor bolted directly to the stock manifold?? I suspect the carburetor in the link is not the replacement you have..
Under any event, if the locator pins at the end of the exhaust manifold have been replaced with bolts, and you're retaining the stock exhaust manifold, You'll need to put those pins back in place.. Or the manifold will crack from the heat cycles.. Because of the "bolt together" design of the intake and exhaust manifolds, there is a trick to getting every thing lined up prior to tightening the manifold to head bolts.. If the procedure isn't adhered to, you WILL HAVE leaks -- both on the intake side and exhaust side...
RustyPile is online now   Reply With Quote
Old 12-21-2018, 11:38 AM   #2
Tiiimmmaaayyy
Sorry for the wrong link. It's the same 1 barrel carb that was from chevy. I copper permatexed the manifolds and was careful not to use too much torque on the end bolts on the manifolds so I doubt that I'll have any trouble. Thanks for the tips and I'll keep an eye on those manifolds.
Tiiimmmaaayyy is offline   Reply With Quote
