Old 12-23-2018, 11:21 AM   #1
rjs53
column to rag joint
I need some help getting from my column 1"DDX3/4 to the rag joint extension 1"x3/4. What do I need at the column to the 3/4 DD for vibration or movement, there was a greased socket with a rubber boot, which I assumed was for any movement
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 12-23-2018, 03:09 PM   #2
rjs53
Re: column to rag joint
Here’s what I’m talking about. The end of the column is 1’ OD with a 3/4 ID. Can I put a coupler there or should I put some kind of joint for movement? Thanks
2003 Dodge 2500
1969 C10
Old 12-24-2018, 10:29 AM   #3
Sheepdip
Sheepdip's Avatar
It's hard to see in your pic what type/size you got coming off the rag joint.
The rag joint will take care of the vibration issue. If it is DD and the rag joint deflection is not excessive I would weld a like extension on it and continue with more DD shaft to the column 1"DD and install a 1"DD X 1"DD or 1"DD X 3/4"DD (depending on your application) universal at that point.
If you require a bottom u joint at the rag joint (excessive deflection) DD shaft, you'll have to a Heim Joint somewhere in the middle to keep the whole shebang from flopping around.
Sheepdip is offline   Reply With Quote
Old 12-24-2018, 11:14 AM   #4
rjs53
They both accept 3/4 DD. I figure the rag joint would take care of vibration, but there was a greased joint where the old DD and column came together. And it was splined.
2003 Dodge 2500
1969 C10
Old 12-24-2018, 11:26 AM   #5
Sheepdip
Sheepdip's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1366993175
Like this? ^^^^^^^^^^^^^^^^^^^^
You no longer are using that I'm assuming since it hooks up to a factory 3/4-36 spline on the end of the factory column.
You measure DD shaft across the wide radiused ends, most after market columns are 1"DD.
Old 12-24-2018, 11:35 AM   #6
rjs53
That's it! The new column accepts a 3/4 DD. I was going to put a new shaft from the rag joint extension to the new column and insert a set screw at the column, but wasn't sure if I needed a u joint there seems the original had what you pictured. Thanks for the help
2003 Dodge 2500
1969 C10
Old 12-24-2018, 12:53 PM   #7
Sheepdip
Sheepdip's Avatar
If I think what you are saying is you are going to insert 3/4"DD into your 1" DD column and add a set screw?
That's not the way to do it. You will need a 3/4 x 1 universal for misalignment …..trust me.
Old 12-24-2018, 03:03 PM   #8
rjs53
That's exactly what I wanted to know, thanks. I could make it work without the universal, but that doesn't always mean its ok. Thanks again for your help.
2003 Dodge 2500
1969 C10
Old 12-25-2018, 10:10 PM   #9
hayhauler71
hayhauler71's Avatar
Here is a pic of mine with a stainless steel u joint
Fuzzy
hayhauler71 is offline   Reply With Quote
