How does this horn button come off?
I need to remove this steering wheel soon. I hate to start prying at the wrong place and destroy it. How does it come off?
Re: How does this horn button come off?
Just pull strait back on it. If you see the tab at the 10 o clock position in your last picture that is what is holding it on there are three of these around the button. What the button is holding onto is a pressed board that is screwed to your steering wheel adapter. You can break it if you pry against the board. I usually get it started with a flat head and finish it off by hand. Know that a spring is on the other side of the button an may come flying out-there is not real danger other than maybe your eye but don’t loose the spring as you will obviously need it again.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
