Old 12-25-2018, 05:27 PM   #1
DCLefler
Big back window
I bought a cab with a big back window with minimal rust the problem is it look like someone used a can opener on the firewall. It has gaping holes in several locations. I have a extra cab to cut panels out to patch it. My question is are there any aftermarket sources for a firewall to replace or cover it with something like stainless?
Any help will be greatly appreciated
DCLefler is offline   Reply With Quote
Old 12-25-2018, 05:38 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Big back window
http://67-72chevytrucks.com/vboard/s...d.php?t=710233
DPowers is offline   Reply With Quote
Old 12-25-2018, 11:38 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Big back window
http://directsheetmetal.com/Store/in...ort=20a&page=2
https://www.selfmadefab.com/product/...rewall-shavers
https://vannattafabrication.com/new-...oth-beadrolled
http://www.yogisinc.com/index.cfm/pa...cat/cat507.htm
http://modshopinc.net/store/index.ph...roducts_id=637
Old 12-26-2018, 12:05 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Re: Big back window
Depends on how bad yours is. The previous owners of my truck, cut and drilled a bunch of holes in the firewall and floor (88 extra to be exact). I spent a lot of hours welding, hammering and dollying my firewall.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-26-2018, 09:43 AM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Big back window
Its not BIG BACK WINDOW.
Proper terminology is Panoramic View 60-63 or Full View 64-66.
No one cares , i'll be quiet now.
Old 12-26-2018, 10:02 PM   #6
Johns 66
Johns 66's Avatar
Re: Big back window
Teachers pet
Johns 66 is offline   Reply With Quote
Old 12-27-2018, 12:28 AM   #7
DCLefler
Re: Big back window
Thanks for the links on the firewall panels and the education on proper window description.
I'm new to posting to this site so I hope the photo will up load ok.
Old 12-27-2018, 09:26 AM   #8
nsb29
nsb29's Avatar
Re: Big back window
What a mess
nsb29 is offline   Reply With Quote
Old 12-27-2018, 10:37 AM   #9
pimpston65
pimpston65's Avatar
Re: Big back window
I care!!!
pimpston65 is offline   Reply With Quote
Old 12-27-2018, 01:51 PM   #10
aerotruk63
aerotruk63's Avatar
Re: Big back window
Originally Posted by pimpston65 View Post
I care!!!
Exception to the rule , but that applies to many things.
Old 12-27-2018, 01:54 PM   #11
aerotruk63
aerotruk63's Avatar
Re: Big back window
Keep your rear panel but find a better small window cab and convert. Lots of work to bring it back , unless you don't mind the challenge.
Old 12-27-2018, 04:19 PM   #12
straight6chevyguy
straight6chevyguy's Avatar
Re: Big back window
At first I was going to joke and just tell you to cut some sheet metal and pop rivet it over the holes..... But after seeing the pictures..... WOW! What the heck where they thinking?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 12-27-2018, 06:03 PM   #13
ImpalaJim
ImpalaJim's Avatar
Re: Big back window
I look at them pics and all I can is WTFMF
ImpalaJim is offline   Reply With Quote
Old 12-28-2018, 12:07 AM   #14
Captainfab
60-66 Nut
Re: Big back window
And it's an AC cab as well. If the rest of the cab is decent, I think I would opt to just replace the entire firewall.
Old 12-28-2018, 12:10 PM   #15
DCLefler
Re: Big back window
The rest of the cab is in very good shape. I have another firewall. The question for the group is. If I cut the parts that have been mangled and patch them in will there be enough support or should I try and replace the entire fire wall.
Old 12-28-2018, 12:37 PM   #16
vin63
vin63's Avatar
Re: Big back window
For me, it would take less time to replace the entire firewall. I would brace the cab, cut out the firewall, remove and weld in the firewall from the donor cab.
Old 12-28-2018, 12:52 PM   #17
DCLefler
Re: Big back window
Pardon my lack of experience but what do you mean when you say "brace the cab"?
Old 12-28-2018, 01:08 PM   #18
vin63
vin63's Avatar
Re: Big back window
Since it appears that the cab is not mounted to the frame, and if you remove the firewall (a significant component to the structural integrity of the cab), it would be good idea to brace the cab before cutting out the firewall to keep it square while you cut, grind, hammer, weld, etc. Even if it was mounted to the frame, I would still tack weld in a few diagonal braces similar to this from a member on this forum:
Old 12-28-2018, 03:31 PM   #19
DCLefler
Re: Big back window
Thanks that's is what I thought you meant. I keep asking myself what was i thinking.
It will certainly be a learning process. I already have a runner that I am going to 454 in so I will have plenty of time to do the cab work
454 swap
