#26 |
Re: What mufflers Are you using?
whoops, forgot to specify. 3000.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
#27 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I put these on my bone stock with factory ram horn exaust manifolds and an H pipe with 2 1/4 inch pipes exiting behind the rear wheels to the side. Seem a touch loud til they warm up then nice mellow tone for normal driving butreally bark when accelerating hard. No drone at Highway speeds.
http://www.dynomax.com/catalogsearch/result/?q=17747
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#28 |
laying low
![]() Join Date: Mar 2001
I would like to see the Revolver Magnaflow truck in person. You know all those muffs sound much different than on video.
#29 |
I'm thinking of going with the same mufflers as my Camaro. Got a little rumble under normal driving, when you put your foot in it they have a valve that opens and it comes to life. I'm sure they'll sound different without the LS motor but kinda the best of both worlds for me.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
#30 |
That Does sound great. It's a big block so will sound different than small block in tone.
Nice truck! Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
#31 |
Long tube headers with purple hornie header glasspacks. SBC with L79 cam. They sound just like a regular old school thrush. Guess it's a little loud, but I don't have a radio or A/C and everything I have is loud, greasy and stinky. I just think You can't beat the sound of an old school glass pack. No tinny sound from idle to WFO. Pipes out the back help with cab noise and some neighbors need to be annoyed. Mine is not a daily driver either and that makes a difference.
#32 |
Like the other guy on here with Spintech's said, they're annoyingly loud on the interior. Magnaflows with electric cut outs would be my preferred choice, next time.
#33 |
Another interesting option: BBK has a muffler you can manually adjust the sound. Like having 3 mufflers in one.
https://www.bbkperformance.com/3-in-...uminized.html#
#34 | |
#35 |
Little more tame sound that barks when you hit the pedal, the flowmaster delta 50 is a good choice
#36 |
Sawlog ;my mufflers are the round 3 inch straight through style, with Sanderson short headers,if you go onto you-tube you can listen to many different manufactures muffler sounds.
