Correct Air Cleaner Assembly for 1969 K10 with 350 V8 with Quadrajet?
I have a 1969 K10 with a 350 V8 and Quadrajet carb. Carb has divorced choke. Truck has power brakes and power steering. No A/C. Truck has 4 speed manual trans if it matters.
I'm trying to find a correct air cleaner assembly. I have come across several different assemblies, but don't know which one is correct. Does anybody have a picture of what would have been original on my truck? Thanks in advance. |
Who's got steelies?
![]() Join Date: Feb 2006
Re: Correct Air Cleaner Assembly for 1969 K10 with 350 V8 with Quadrajet?
This is the setup on my 1970 c20 burb, I think it is the same as a 69, c or k should be the same.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Same air cleaner, but a little cleaner. Should have a heat tube off manifold also. '69-'72 is the same.
![]() Join Date: Feb 2014
Some early 69 didn’t have a dashpot. Otherwise identical to the pics above.
Thank you, everyone.
I picked up this air cleaner assembly today from a guy here in KC. It looks correct based on the photos you provided. It’s in good shape and should clean up nice. |
Did you get the spacer that goes between the air cleaner and carb ? It has the connection for passenger side valve cover.
71 C-20 07 Magnum RT AWD |
Here is a stock set up on a 72.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
No - but I already had that piece and the hose. Based on one of the pictures - I believe what I have is correct. Thank you for asking.
Good luck with your K10
