Truck build
Ok, I just joined this site several months ago as I stumbled on and bought a 72GMCK1500. I wanted to take some time and think about potential build ideas.
Before I reveal the direction I’m leaning towards I would all of your thoughts and ideas. Current state- original paint, pretty solid. Tired 400 motor , leaky trans, older shocks, some new suspension parts. New 33” nice stance. Interior is real clean not much needed there except some tunes! Plan A- full restoration to original paint, 4” lift new driveline and tight suspension a/c Plan B- driveline and all suspension upgrade. Relocate gas tank, for stereo and leg room, maybe remove side tanks. Upgraded stereo and a/c. Open to ideas? |
laying low
![]() Join Date: Mar 2001
Re: Truck build
Wow. It sure looks good. Fix the leaks, wash it and enjoy it as is? As some say, it's only original once.
![]() Join Date: Feb 2009
Re: Truck build
What do you plan to use it for? If it's for travel and driven a lot, I might run with plan B and install an LS. That or blow all kinds of cash for street rod 4x4
![]() If you appreciate an original build and aren't going to use it a lot, then plan A, IMO. Don't know what to tell you on those side tanks. Both my trucks had them, and at this point they aint worth a (*^). Perhaps you can restore or replace.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Truck build
I'm a plan B guy. It looks good and its only original once as someone said. If the motors tired, then an ls swap would be good for a daily, that would justify getting rid of the saddle tanks. A decent salvage ls/trans is gonna cost about the same or less than a rebuild on the current motor and trans. You'll still have the fuel system and some wiring to do with the ls swap. So ya plan B, even going with rebuild on original SBC.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
Re: Truck build
Moving tank doesn't buy you leg room. Seat is already up against the cab wall. I figure properly plumbed, the tank is safer in the cab, actually.
If the cab deforms enough to rupture the tank, you're long since dead and gone. It'd be like a Viking funeral. Whereas if you get sidesswiped or rear ended with a frame-mounted tank... Personally, I think that's a beautiful truck and color scheme and I'd do it 100% stock, but that's why they made a million of 'em, do whatever you like!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
![]() Join Date: Jul 2015
Re: Truck build
That is very nice looking just the way it is. As for the your current plan I would say an updated motor or just keep it stock and rebuild it.
They are nice just the way they are and you will get tons of compliments without doing a thing. They do turn into money pits with the custom work. The do become more valuable the less you do to them. |
![]() Join Date: Oct 2009
Re: Truck build
Plan C
![]() Plan C1 (if budget is a bigger concern): same as above except with an L31R in place of the HT383. It's almost a blessing to not have the original engine in this case, you're free to go any direction (or maybe this is just a problem for me when I have a tired original engine... ![]() EDIT: toolbox made some GREAT points. Bone stock is never wrong - and it's usually the least expensive route, unless doing a stock frame-off resto. So, I'm kinda curious - I see highlander plaid peeking out there... Is this a converted 2WD truck? And when you mention 400 - does it have a big block 402? (as in the 2WD trucks original 71 402 in it still)? If so, I have a Plan D... Got a SPID pic or a VIN you can share? Last edited by jocko; 12-30-2018 at 01:38 PM. |
Re: Truck build
Dave, where did that gorgeous white/green GMC come from? Is that yours? It's stunning.
![]() ![]() Join Date: Oct 2015
Re: Truck build
Sharp looking truck. Would love to see some more pictures. After doing the build on my K1500 short fleetside, I would lean toward going thru all the mechanicals and keep the truck the way it is. If the engine is a 400, I don't think it is original. With a V8, I think you could only get a 307 or 350. If you go plan A, let me know if you would want to swap leaf springs. My K1500 has a Tuff Country 2" spring lift that measures out more like a 4". My plans are to drop my truck back down to stock height this coming summer.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
Re: Truck build
Oh WAIT! Sorry, I totally forgot - this is Pete's old K1500, right? That's an original K and he added the plaid. It looks great. I've always had a thing for this truck
![]() Boy oh boy, I'd keep the exterior as, freshen up whatever needs freshening, replace the engine if you want since it would not be original, and then do what you like with the stereo in as stealth a fashion as possible. Great truck you have there. I think I already asked this at some point in the past, but did the camper shell come with it or did you buy it as is? |
![]() Join Date: Oct 2011
Re: Truck build
Nice truck...some great ways to go on this.
As for the 400 ci....big block? if so that would have been added or exchanged for the original engine given that GM didn't put 400's in the 4wd trucks then. If its a 400sbc...that is different but still pretty cool...and I like the 400 sbc's myself. Regardless, nice truck, nice find!!....more pics! All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Re: Truck build
Very nice as is I would do a few upgrades and drive
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#13 | |
Re: Truck build
Would really like A/c for the hot mi days Keep suggestions coming |
Re: Truck build
Here are some of the radio options I was talking about, some modify your AM radio, some are hidden second radios, etc -
http://www.garytayman.com/ http://mikehaganantiqueautoradio.com/ https://www.joesclassiccarradio.com/ http://www.antiqueautomobileradio.com/ http://www.turnswitch.com/speakers.htm https://redirad.com/ https://www.classiccarstereos.com/secretaudio-sst.html https://www.youtube.com/watch?v=de5RbKvdnjQ https://www.youtube.com/watch?v=vBwsa0QR0I8 http://67-72chevytrucks.com/vboard/s...d.php?t=229621 http://67-72chevytrucks.com/vboard/s...d.php?t=617011 |
#15 | |
Re: Truck build
Where do most put speakers? |
#16 |
Re: Truck build
There are kick-panel covers available that allow speaker mounting. Or you could go under the seat. Please don't cut 4 inch holes in the door. I just paid a body man to weld patches in my doors, and repaint.
#17 |
Re: Truck build
I've always just put a quality one in the stock location - but that's just because it's been good enough for me, others may like better (bigger) speakers. I THINK there is a board member that sells a metal bracket/panel thingy that allows you to mount them behind the seat in the corners of the cab. Not sure if it interferes with the filler neck - might only be for relocated tank trucks (or it might actually fit, I just don't know). I would avoid holes in the doors as well. I've only owned one truck that DIDN'T have the holes cut out! Ha.
EDIT: Here you go, found it: http://67-72chevytrucks.com/vboard/s...d.php?t=476976 And they are indeed for trucks with relocated tanks only. |
#18 |
Re: Truck build
No holes will be cut in pristine doors
Any shock recommendations ? |
#19 |
Re: Truck build
On top of the dash for an AM radio
#20 |
All about them K’s
![]() Join Date: Jun 2014
Re: Truck build
I saw this truck in person when Pete had it. I wouldn’t touch a thing on it save maybe a motor/trans if it needed it. Paint and body looked amazing for factory when I saw it ~2 years ago. I’m definitely with mark on this one. Fix the small things that need it so it can be reliable and safe and stop there.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
