Old 12-30-2018, 09:41 PM   #1
rjs53
1969 C10 water pump
Ok so in my 69 c10 I have a sbc350. This truck came with a 350ci, but not the one that's in it. The motor I have now is out of a 1978 K10 or 2500, according to the numbers I've found on the motor. The Po I got it from I'm assuming put this in. The water pump is a long pump and the outlet to the bottom hose is clocked to far down, causing the lower radiator hose to kink on the frame. I got a water pump for the 69 year but no provisions for the power steering or alternator. Alt is on passenger side. I don't want to buy new brackets, was wondering if anyone else has run into this and what you may have done? Pictures if you got em of your set up. Thanks
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 12-30-2018, 09:47 PM   #2
toolboxchev
Re: 1969 C10 water pump
I stick to stock due to ease of replacement of things when they go bad. Usually keep some spare parts on hand knowingly anticipating when something will be going bad.
toolboxchev is offline   Reply With Quote
Old 12-30-2018, 09:56 PM   #3
jocko
jocko's Avatar
Yep, 69 will be a short pump, you have a long one - if you swap anything, you kinda have to swap all. I'd look for a different radiator hose and use the long version of the pump, otherwise, brackets, alignment, all that stuff is out the window. It's a lousy problem - I am in the same boat, trying to decide which way I'll go as well while I consider my engine options. Would really just like to find an original 72 truck 350 that hasn't been bored out a few times already
Old 12-30-2018, 10:27 PM   #4
rjs53
I'm thinking about trying a flex hose, but with the angle og the outlet its gonna be a tight bend. I'll try it if that doesn't work then its back to the drawing board. Thanks for your help.
2003 Dodge 2500
1969 C10
Old 12-31-2018, 12:23 AM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
I will touch on PS brackets . Alt brackets the right Pulleys systems. The driver side alt bracket Using of the Newer style fan clutch the right shroud and if you can find them using the 7 blade metal Dodge 340-440 metal fan blades for maxuim cooling that will take the 1974 454 extreme duty fan clutch that will work on are 283-327 short water pumps
This will help some of you that are running the edalbrock alum Performer intake.
I will touch on using the temp sending unit switch on the intake and using the thermostat housing from the 1960-1968 that used the straight forward housing instead of the the one that curves tords the drivers fender.I will show you witch hose to buy that will line up with your top radiator out let and keep it out of the way of the Alt.
I will show you the driver side alt brackets that make all of your new re pop M&H harness work flawlessly
stsalvage is offline   Reply With Quote
Old 12-31-2018, 12:30 AM   #6
stsalvage
Scrapper 1
stsalvage's Avatar
this is on the ALT brackets the right ones for the 1969-72 but can work on the 1960-72 as long as you don't have HUMP beads.
the ALT brackets i'm showing you where ment for car or truck the longer reach bracket meaning the black one is the factory truck one the brown one is for the car they both work the same one takes a long belt the shorter one takes a shorter belt
Old 12-31-2018, 12:36 AM   #7
stsalvage
Scrapper 1
stsalvage's Avatar
the right water pump if your not running AC is the ones i'm showing you the crack pulley brackets are 2 single belt pulleys an the top one is a single belt pulley
Old 12-31-2018, 12:39 AM   #8
stsalvage
Scrapper 1
stsalvage's Avatar
The right shroud an all the pulleys work together
Old 12-31-2018, 12:44 AM   #9
stsalvage
Scrapper 1
stsalvage's Avatar
For the last one is the Best Power steering bracket GM ever made its easy to work with to adjust and to work with by changing in and out new hoses for old wore out hoses
Old 12-31-2018, 01:22 AM   #10
rjs53
Great information thank you. Now I just have to find them.
2003 Dodge 2500
1969 C10
Old 12-31-2018, 01:53 AM   #11
RTHarvey
Well, the user name of the guy that provided all that info is "STSalvage". Maybe he has some?
RTHarvey is offline   Reply With Quote
Old 12-31-2018, 07:29 AM   #12
Myoldtruck
Myoldtruck's Avatar
Both of my trucks came with the long style pumps when i bought them. both with alternators on passenger side, and both wiring harness butchered up to make them work. I completed my yellow truck about 2yrs ago, with no problems so far. Working on my green truck now this week.
Do the complete change over back to original for keeping it simple. Order your new water pump, fan clutch, belts and hoses. Get a new fan shroud. This is a weekend job once you have the correct pulleys.
Myoldtruck is offline   Reply With Quote
Old 12-31-2018, 08:32 AM   #13
twoskies
twoskies's Avatar
ive got a 1972 c10 with a 1979 elcamino motor in it, kinda same
had to goto junkyard and get all pulleys and brackets from a 1973 to i think 1985, got lucky on mine,
found a 1982 same setup as my truck, no ac, has power steering and manual transmission, although i think the pulleys would of been right either way
i already had an alternator that was right(pass side) the power steering pump on the 72 would not work, i took the junkyard one
now all pulleys and equipment lines up very well
on the radiator hose,(new 3 core aluminum radiator) i went to advance auto parts and spent some time there,
part # E72048
funny it fits a 2000 to 2003 dodge dakota with the 5.9 v8, lower hose
molds around everything very well
good luck
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 12-31-2018, 11:56 AM   #14
rjs53
I may have the right PS bracket, but its been rigged to work off the alt mounting position. That's why I asked for pics, the PO was the king of jury rig, (well maybe not the king) but he was really good at it. I'll look at it and see if It can be made to work in the proper position, possible a different pulley may be needed. This truck originally had AC so I plan on going back to it.
2003 Dodge 2500
1969 C10
Old 12-31-2018, 03:16 PM   #15
68Gold/white
Using a long water pump would be easiest...for now...BUT
Beware, not all long pumps are the same...
If you know for sure that the engine is a 78, you are good.
The 77-86(long) pumps are all the same...The 76 pumps are a one year only deal. I can't remember what the differences were on 73, 74, and 75 pumps they might all be the same.
The only short pump used from 73 on was for a Corvette, and it was different from the 72 and earlier short pumps. There MAY be some weird application of a short pump from 73 and on, that's not a pickup, regular car of Corvette, but I don't remember applications that obscure....
68Gold/white is offline   Reply With Quote
Old 12-31-2018, 05:22 PM   #16
twoskies
twoskies's Avatar
Hey
Here’s mine. 79 motor out of el Camino. In 72 c10
Old 12-31-2018, 06:03 PM   #17
stsalvage
Scrapper 1
stsalvage's Avatar
remember Elcomino's have a lack of room under there hood.That looks like a nightmare.You really need to find some one online that is parting out a truck and buy all the front brackets Pulleys and PS pump brackets.The set up you have is made for just one truck an that is Elcomino's spend the 250.00 trust me you will like your self in the end.
Old 12-31-2018, 06:06 PM   #18
stsalvage
Scrapper 1
stsalvage's Avatar
Trust me You go on ebay or this site or Craigslist you will find people that have all the brackets
Old 12-31-2018, 06:39 PM   #19
rjs53
Twoskies, you have the same set up I have. Was hoping I had the right brackets but no such luck. All this because the frame has a lip for strength I think, that is sticking into the bottom hose. I might just box the frame there and trim the lip off.
2003 Dodge 2500
1969 C10
Old 12-31-2018, 07:18 PM   #20
68Gold/white
Do you have a picture of that??? I would like to see what's up there...
No big concern to box the frame there. On the big block pickups the frame was narrowed quite a bit on the top, for exhaust clearance. I wonder if another hose might help.
Old 12-31-2018, 08:00 PM   #21
stsalvage
Scrapper 1
stsalvage's Avatar
I took more pics of what it should look like with small water pump
Old 12-31-2018, 10:58 PM   #22
rjs53
That's it stsalvage, except with newer style water pump outlet extends down further and causes the rad hose to bend over the frame rail.
2003 Dodge 2500
1969 C10
Old 12-31-2018, 11:53 PM   #23
Sawlog
When I bought my 69 c10 it had the alternator on the driver side and the upper radiator hose played on it.
When I built my new motor I bought a fully kit from summit. I was 100 bucks or so. It moves the alternator to the passenger side and comes with all the pulls and new steering bracket. Very happy with it.
Sawlog is offline   Reply With Quote
