Old 01-01-2019, 10:48 PM   #1
B. W.
B. W.'s Avatar
Dimmer Switch Screws
Does anyone know what size the pan head screws are that hold the dimmer switch? The PO broke the screws off then drilled them out, etc, etc. I want to go back with the original size hardware.
Also. on the backing plate are there nuts welded on or is it just tapped? Thanks.
B. W. is offline   Reply With Quote
Old 01-01-2019, 11:36 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Dimmer Switch Screws
Mounts using two #3 phillips panhead screws with integrated star washers. The screw threads are 1/4-20 x 7/16.
The RH screw mounts a rubber-coated J-clip wire retainer. This retains the wires routed to the rear cab, for the dome and fuel tank sender.
The backing plate itself is tapped, and the plate is welded on.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-02-2019, 11:49 AM   #3
B. W.
B. W.'s Avatar
Thank you, that's exactly what I needed! Great pic. My plate is all boogered up.
