Old 05-22-2004, 11:09 PM   #1
Bryan H
Bryan H's Avatar
Minitubbing A Fleetside
Anybody ever minitubbed a fleetside with a steel bed? I'm thinking of doing this. I was going to leave the stock width rearend in it but take the wheelwells out and cut the bed and then widen the factory wheeltubs and then measure for the right backspace for the wheels. I have leaf springs and also a factory steel bed floor. I have the truck completely disassembled so now would be the time. After doing some measuring I think you could widen them about 3" without hitting any braces under the bed floor. I was wondering if anybody has ever done this and how wide of a wheel did you end up running? I did a search and could'nt find anything. Any pics is appreciated. Thanks, Bryan
Bryan H is offline   Reply With Quote
Old 05-22-2004, 11:22 PM   #2
bad69
Struggling Artist
Mini tubb
bryan; I too am in the process of mini tibbing my 69 fleet, i widened mine 3.5" and sectioned two wells togather to try and keep the factory look. No pics as of yet but will have some as soon as the welding is done. Mitch
69 1/2 ton lwb lowrider
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
bad69 is offline   Reply With Quote
Old 05-23-2004, 02:52 PM   #3
Bryan H
Bryan H's Avatar
Thans for the reply Mitch. Keep me updated.
Old 05-23-2004, 03:30 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
chevyfatman has a blazer with the minitubbed rear, but it was like that when he bought it and I know I don't have any details.
It was kinda hard to see in the back of it (see pictures) but when we pulled 1/2 of that stuff out, you could see they were wider than stock. (by then it was too dark for pics)
Old 05-23-2004, 08:07 PM   #5
SCOTI
SCOTI's Avatar
I did mine, but they're not exactly mini-tubs. They measure about 21" wide & they are the stock tubs widened. Since my truck has a coil rear end & trailing arm suspension, I could run much wider wheels than possible w/a factory located leaf suspension. I had 15x14's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-23-2004, 11:31 PM   #6
crazy longhorn
Fabricate till you "puke"
I did a 5" stretch on the longhorn.....cant use all that space till I ditch the leafs springs tho. here are a few shots.... http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-24-2004, 07:43 PM   #7
Rdrdave
Broke and still trying
Rdrdave's Avatar
What type/size tire did you have? I have a 68 lwb that I plan on doing this too (wood bed) but am not sure of what size rim/backspacing/tire dimenions to use. ANy pics would also be appreciated.
Rdrdave is offline   Reply With Quote
