Junior Member
Spindels rub on 15" wheels or A-arms?????
Ok I have to start by saying thanks to all who have helped my with the updating of my 72 c-10 LB, it was grandpa's and his spirit would haunt my if I F*&^'d it up
![]() I was just about to order the 4/6 drop kit from Early Classics when I was told by the guys at RICKS (gotta say they are great & have help me tons also) said that since I was gonna run 255/60's on the 15x8 truck rallys that the drop spindles would rub on the wheels or on the A-arms wheel I turned & that I would have to cut the A-arm (bad idea????) or run less ofset wheels or 17" wheels. Anyone else run into this???? Thoughts or experiences???? Thanks, 1 Leg Lance |
Member since 2000
i never got rubbing problem with my blazer, hmmmmm. and i got my wheels from wheel vintques
i knew a guy that slammed a dodge dakota to the ground and he had to grind a little off his lower a-arm to keep it off his wheel, but i've never ever heard of a rub problem on one of our trucks, i don't know ricks, but they may have been trying to get you to buy from them instead of early classic
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
I have the 2and1/2 drop spindels from ECE and run 15x10s with 275 60 I5 have not driven the truck but dont see any problems.
70 swb restored by myself and some help from this board!! I hope to drive it some day!! portland OR |
Out of the carpool lane.
...that's what it sounds like to me. I don't think you'll have any problems. Here's what they may be talking about: a friend of mine had a 1980 C-10 (same A-arms) and used Belltech 3" drop spindles w/ 15" tall rims. The clearance was very minimal (1/4"-1/2") but it was definately do-able. If you stay with 2-1/2" or 2" you'll be fine. BTW, I bought mine from Summit and am very happy with them-they say they're 2".
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
I just got my 2 1/2 " Belltech spindles and they show where to grind the A arm if need be, it must be a common prob but an easy fix if you don't mind a little grinding.
71 GMC 1500 LWB |
aka Crusher, Crushergmc
I've only heard of 3" drop spindles rubbing. You should be fine with 2.5"
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
![]() Join Date: Apr 2002
I used to have 15x7 front wheels and they barely rubbed my lower arms w/ 3" drop spindles. Little grinding, easy fix.
This new reply page looks pretty high-tech to this computer dummy.
'69 Chev Cust/10 swb, 350/700R4, 5"/6" '70 Chev C10 swb, 67 front, 454/700r4, 4"/5" '73 Chev stepper, 350/3 spd '84 Chev K20 350/4 spd '91 GMC 1500 Suburban 4x4, 350/700R4 |
14.1 @ 96MPH
*scratches head*
Tell Rick to have a look under the front of my truck, then. I've got ECE 2.5" drop spindles (I take it you're going to do a 2.5" spindle drop and a spring drop as well?) and my clearance problems were with tire-to-fender, not wheel-to-spindle, and I've got 15-inch 6-lug rallys...I don't know if they're x7's or x8's... They could use a tad more backspacing, but 245/60-15's fit perfectly up front. I don't think the extra 1.5" of drop is going to make a major difference in spindle clearancing. A shame Rick doesn't do so much of the "day-to-day" things on these trucks anymore. He built and installed the TH400 in my truck which works flawlessly to this day, but now I need a 700R4 and he doesn't do installations anymore...just restos and parts...
Project1970 - LS1 Swap Complete! ![]() |
Everyone with the clearance problem I am assume are running 15's correct. Any problems with say 17-18's rubbing? Anybody..
Ken Smith 99 C5 Torch Red Coupe 85 Chevy Candy Apple 70 Chevy 1/2 in process.Semi-gloss black powdercoated frame & suspension, disc brakes up front, 3" drop spindle(Beltech) 5 lug 3.73 rearend, ZZ4, Sanderson headers, 700R4, Air Ride system, Summitt 16 gal fuel cell, Holly mech. fuel pump, |
