Old 01-04-2019, 09:19 AM   #1
nsb29
nsb29's Avatar
Re: Question: In cab - in tank electric fuel pump?
used my original sending unit as a return cannibalize the second unit for the fuel pump and a Corvette filter
nsb29 is offline   Reply With Quote
Old 01-04-2019, 10:07 AM   #2
weim55
Now that's a good idea! Was wondering how I could fit all that through such a small hole. Problem solved! Any thoughts surrounding the pump itself?
Thanks for the info,
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 01-04-2019, 10:55 AM   #3
nsb29
nsb29's Avatar
Pm sent
Old 01-04-2019, 10:59 AM   #4
spudder
Active Member
I like the idea of an in tank pump, but I wonder if it will be too noisy inside the cab? Just thinking, but would not want you to do all the work and end up with something unsatisfactory.
Your thoughts?
spudder is offline   Reply With Quote
Old 01-04-2019, 06:39 PM   #5
nsb29
nsb29's Avatar
Your thoughts?
You only hear it for a few seconds when you first turn the key on
Old 01-04-2019, 09:19 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Your thoughts?
Keep it topped off, loud exhaust and turn up the tunes should cover it!
Im sure they are not that noisy!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-05-2019, 01:12 AM   #7
weim55
I thought about the noise inside the cab too...... The frame mount pump makes a good bit of noise itself and I don't care for it. Assuming the in tank pump will just have the same quiet 'buzz' most late model trucks have and I think I can deal with that. Might just do some dynamat over the outside of the tank if it's too annoying.
Old 01-04-2019, 03:10 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Nice!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
