![]() Join Date: Aug 2004
Rebirth of Clyde
Starting to document the transformation of my truck. I have had Clyde since 1989, I got him road ready and started to drive him. Sorry no pictures of the beginning.
These are the things that I have done to my truck prior to build thread. Rebuilt front suspension 2.5” CPP drop spindles 2” drop springs 72 front sway bar Shock relocators KYB shocks Rebuilt rear suspension Rebuilt 12 bolt 3.73:1 gears Eaton Posi Relocated fuel tank Boyd’s 63-72 c10 19 Gal tank American Racing radiator 2005 4.8l fi motor 2002 4l60e trans Tune by: Nelson Performance Harness by: Clinebarger
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 04-28-2019 at 04:26 PM. |
Re: Rebirth of Clyde
Here is Clyde in 2002, high pockets and all.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 09-06-2018 at 10:27 AM. |
Bed rebuild. 2016
New wood, stained like MAR-K has on their site. 67-72 C10 Sport Bumper also
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 09-06-2018 at 10:28 AM. |
Tear down for paint
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
and the dirty work begins
also added the center AC vent and side vents from Corvette Jim
Sanding and sanding
interior paint, turned out darker than I was looking for but I still like it
Exterior paint. no I didn't do a color change, I did think hard about the blue\white as well as green\white.
more of the exterior paint work
More paint work
Clyde, is Looking Pretty Sharp!
I decided to black out the rear grill area, hopefully this will make the chrome grill pop!
removed the Dolphin gauges and went with the Autometer Classic White, with GPS Speedo
also I cleaned up under the hood, I found real good inner fenders and radiator support, blasted and painted then painted here and there and cleaned a bunch. I will replace the booster assy for a new one, the one there wouldn't clean up.
#15 |
Sound Deadening and also added a 71\72 c10 accelerator assembly
#16 |
Only some buffing and touch up left
#17 |
after final buff and clean up
#18 |
Added some bling to Clyde today
#19 |
Very nice.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
#20 |
New front springs, rear bumper on and a ball joint replacement.
#21 |
Looks better than ever!
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#22 |
Wow. Got a lot done over the fall months
#23 |
Clean Machine!
#24 |
Wow!
I'm not really a lowered truck fan, but your's looks really good!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
#25 |
Thank You sir!
